Posted 11 Years Ago
Visits: 31.4K
mindprints (12/16/2015) Well, I don't use Word so I wouldn't know about that, but I have noticed that once in awhile after fishing up the particles via timelime selection that they have shown up in the scene window. Unfortunately I didn't remember exactly the circumstances of how that came about:-(Particles are controlled by an Emit setting, which can be either ON or OFF. This can be shown in the timeline as a separate track.
mindprints
mindprints
Posted 11 Years Ago
Visits: 318
mindprints
mindprints
Posted 11 Years Ago
Visits: 318
I've kind of given up on doing the splash and more accurately it was actually a displacement of the water. I did it as a test once and really liked it, but I have never been able to recreate that effect as nicely.
At this point I have just thrown a bunch of clips together. I'll get back to you when the video is finished.
planetstardragon
planetstardragon
Posted 11 Years Ago
Posts: 11.5K,
Visits: 46.0K
this thread got me curious to see if any new software has popped up ..... Interesting find - this guy behind this project http://www.pixie3d.com/ is being supported by Unity3D founder David Helgason ^.^
Posted 11 Years Ago
Visits: 31.4K
sw00000p (12/13/2015) iClone 6 particles have a Bug???:w00t:No, they don't. It's only that they don't appear in the scene manager after the last update, but there are easy workarounds for that. People should just be aware that workarounds are common for many pieces of software, even Microsoft Word.
Delerna
Delerna
Posted 11 Years Ago
Posts: 1.5K,
Visits: 14.8K
Just another thought with the softcloth seeing as you say it works great for 1 or 2 frogs
Have you tried using multiple softcloths with 1 in the correct place and the rest positioned out of the way and then as a frog hits the soft cloth position a new one in place for the next frog? Again, just a thought. Im interrested in the steps you took to do this if you dont mind posting them. There are always many ways to do anything and would like to see what you did
i7-3770 3.4GHz CPU 16 GB Ram GeForce GTX1080 TI 11GB Windows 10 Pro 64bit
mindprints
mindprints
Posted 11 Years Ago
Visits: 318
which particles did you work with and how did you modify them?
mindprints
mindprints
Posted 11 Years Ago
Visits: 318
Thanks for all replies and suggestions. And I too think the skipping stone demo was pretty good though I am trying to do this in an extreme close up.
I am so challenged to get this project finished that I really dont have time to get into Blender which I tried many years ago and found extremely complicated.
I have some greenscreen splashes on my harddisk and when I start putting my scenes into vegas I will try some superimposing there.
The fact is that a one shot splash -- in my case a frog (imported from sketchup) dropping into the ocean -- looks fantastic when I position a softcloth just right on top of the water, but I have a rain of frogs and it's not easy to get the softcloth to handle that. I've tried a plethora of weight maps and cloth sizes to no avail.
As suggested, I am now focussing on the descent of just one of the frogs and using water type props for others. The water type props look a little too geometric, but I turn them on, expand them in just a few frames and fade them out very quickly and this is going to have to do.
As for particles, the present bug in iC6 makes them very awkward to work with and the truth is I have never really understood the timing of those things anyway as there always seems to be an unpredictable delay. But I put the magic fountain particle on a jerky path and let it sort of run amok over the whole scene for extra effect.
planetstardragon
planetstardragon
Posted 11 Years Ago
Posts: 11.5K,
Visits: 46.0K
what everyone else already said.......iclones particle / physics can take you so far, heavy math calculations aren't really good for real time rendering, so you need work arounds.. ....you would either have to make your own in blender as mentioned, or get a green screen splash from youtube and simply composite in the video editor , or make a prop with the video masked out for iclone. It really depends how much detail you want and how far you want to go. I enjoy the compositing approach myself... hitfilm / sony moviestudio combo is very good for that. here's a video i made experimenting with green screen / compositing.
justaviking
justaviking
Posted 11 Years Ago
Posts: 8.2K,
Visits: 26.5K
@Cricky,
The "skipping stones" clip was an excellent start. I have an idea that might help take it to the next level... "secondary splashes."
When the first major splash goes up and lands, that water makes smaller splashes.
I remember noticing the same thing in a big-budget movie called, "Star Wars - Episode I." When their underwater "submarine" surfaced, there was a nice splash effect, but none of the secondary ones, which really spoiled the realism. They probably didn't use iClone ( ;) ) but how about that; you have the opportunity to out-do them! :)
