iClone 6.01 video length and export range
Posted By Ron12345 11 Years Ago
Ron12345
Ron12345
Posted 11 Years Ago
Veteran Member (943 reputation)Veteran Member (943 reputation)Veteran Member (943 reputation)Veteran Member (943 reputation)Veteran Member (943 reputation)Veteran Member (943 reputation)Veteran Member (943 reputation)Veteran Member (943 reputation)Veteran Member (943 reputation)
Posts: 30, Visits: 1.3K
Just like in IC 5, there is a wheel icon next to the frame that allows the frames to extend beyond the default 1800. But when you render the video, it only goes to 1800 even when the right green arrow is at the last frame beyond 1800. In the output range section of render, manually inserting the last frame is always replaced with 1800. If you select all in render output, it stops at 1800 even if the last frame with the green arrow is longer. I have only tried MP4 or AVI at HD 1080p
justaviking
justaviking
Posted 11 Years Ago
Posts: 8.2K, Visits: 26.5K
I've done a project over 4 minutes long in iClone 6.
It sounds like you covered the basics, including the "green triangles."  You are talking about the ones by the scrubber, right?
Does the video PREVIEW okay?  Or does that stop too?
I'm not sure what you're missing.
Ron12345
Ron12345
Posted 11 Years Ago
it plays fine to the last frame, but will only render to 1800
Cricky
Cricky
Posted 11 Years Ago
Skype ID= learn.iclone
Posts: 2.8K, Visits: 13.8K
Ron12345 (1/17/2015)
See Attached
SKYPE ID: rc.650
Ron12345
Ron12345
Posted 11 Years Ago
Thanks for the suggestion, but I tried that already. The "too from" boxes are greyed out, but you can still see 1800 in the "to" and it renders only to 1800.
Cricky
Cricky
Posted 11 Years Ago
Sounds like you are not up to date on the install.
SKYPE ID: rc.650
Ron12345
Ron12345
Posted 11 Years Ago
I have the newest version 6.01.1312.1 and everything works with DX 11, so I am not trying the DX 9 beta. If I open the 02 scene project that is 2400 frames, I can render all 2400. But any old project or even an empty new project with frames > 1800 and green triangle at last frame, only renders to 1800 will "all". With range instead of all, if the "to" is changed from 1800 by entering a number or using the up arrow, it changes back to 1800 when you hit enter or try to render.
I have a new iBuyPower with an I7 4790 @ 3.6ghz, 16 GB RAM, Nvidia GeForce GTX970, Windows 8.1 64 bit. I can run IC 6 at highest resolution with no problems except for this bug.
Cricky
Cricky
Posted 11 Years Ago
Well, I couldn't tell you what it is.. It makes no sense as to why it is doing that. So as they say "Contact RL Support" :D
Lots of Luck...
SKYPE ID: rc.650
