rcsinger29
rcsinger29
Posted 14 Years Ago
Visits: 3.2K
I now know how to add motions to the puppet. How do you add new folders? Each time I add a new folder to the base motion directory, upon loading the motion puppet, iclone freezes and crashes. I would like to be able to add to the core folder as well. Base Motion -Idle -Mood -Move -Talk "whatever you like" motion -Slash -Hack -Fight "Physical Work" -Hammer -Saw -Sweep etc, etc. I noticed the "order list" file and tried to edit it; adding the folder name I created as = 4 but that didn't work either. Is there a way to do this? Add folders to the -Base Motion- and add sibling folders to base motion under the drop down?
warlord720
warlord720
Posted 14 Years Ago
Last Active: 9 Years Ago
Posts: 1.3K,
Visits: 3.9K
This would indeed be a very good feature to organize the puppet interface as mine is cluttered and will only get worse as more motions are added.
With the masking... the motion puppet becomes very central to how I use iClone. My work flow revolves around it.
-------------------------------------------------- I LIVE to anymate, irritate and machinamate. Not necessarily in that order.
rcsinger29
rcsinger29
Posted 14 Years Ago
Visits: 3.2K
Sen did it somehow, but it looks like he replaced one of the other folders with one named Sen and added specific motions to it. It appears as though the program was set up to work this way because: -Base Motion- has a drop down arrow as if to suggest a place for other selections The collections of Mood, Move, Idle, Talk; has arrows left and right as if to suggest scrolling right/Forward, Left/Back to slide through motion categories in addition to the former.
Posted 14 Years Ago
Posts: 8.2K,
Visits: 62.6K
No folder replacement necessary! What you need to do is go to: C:\Users\Public\Documents\Reallusion\Template\iClone 5 Template\iClone Template\Preset In this folder you will see the Base Motion folder. Make a new folder that has the same 4 folders inside it as the Base Motions Folder (Idle, Mood, Move, Talk).  Now when you launch the Motion Puppet, you will have an option besides "Base Motion" that you may choose from the Menu. As far as adding more categories, you might experiment with the "Orderlist.ini" file in the same Preset directory. Work on a copy! I was able to delete a category with no ill effect. I did it in my own motion folder.
Posted 14 Years Ago
Posts: 8.2K,
Visits: 62.6K
One more thing that I forgot in the previous post is that the buttons for the panel live in the folders. Inside each one of the four folders, you will find three BMP files. They are button images for selected, press, and roll-over. Make sure you copy these to the four folders in your own motion directory. If they are not there, you won't see that category.
warlord720
warlord720
Posted 14 Years Ago
Posts: 1.3K,
Visits: 3.9K
Thanks rampa!:cool:
rcsinger29
rcsinger29
Posted 14 Years Ago
Visits: 3.2K
Thanks man. Thats awesome. Can anyone else chime in about renaming the default motion folders and/or adding more? I tried changing the "Mood" folder to "Prf" and I also changed it in the OrderList.ini file but it crashed iClone when trying to load the Puppet. I know it can be done because I seen Sen's pic on a response he posted and he had it named Sen with a custom graphic.
Posted 14 Years Ago
Posts: 8.2K,
Visits: 62.6K
I just had a go at it....And I got it!:w00t:
You don't need to touch the INI file at all. Create as many new folders as you want for your animation categories, just make sure each one has the 3 BMP files for its button. You probably want to make your own graphics.
I did a quick test by copying the "Idle" folder and renaming it "IdleX". I then went into that folder and changed the names of the BMP files to:
IdleX_Click IdleX_Def IdleX_Over
Sure enough, I got a fifth button and had to use the arrow to move sideways in the category list. You do need all three!
The categories list alphabetically from left to right it looks like. My "IdleX" tucked in just to the right of the original "Idle". Not sure what that INI file does.
rcsinger29
rcsinger29
Posted 14 Years Ago
Visits: 3.2K
That's awesome man. Thanks a lot. I tried using custom bumps hat I made with preview from iClone but they are too big. I am going to Streamline your and Sens input into one post for anyone who still doesn't know how to do this. It's priceless info.
Pochontas
Pochontas
Posted 13 Years Ago
Last Active: 8 Years Ago
Visits: 128
My problem is I first used transform to move character from one place to another thinking I'll add motion for legs via motion puppet later, but when I do that (later) character just stands in one place and moves his legs. Is there a way for it to not ignore moving I set in transform bar earlier?
