4k monitors interface scaling
Posted By Yo Dojo 3 Years Ago
Yo Dojo
Yo Dojo
Senior Member (317 reputation)Senior Member (317 reputation)Senior Member (317 reputation)Senior Member (317 reputation)Senior Member (317 reputation)Senior Member (317 reputation)Senior Member (317 reputation)Senior Member (317 reputation)Senior Member (317 reputation)
Posts: 21, Visits: 93
is thehttps://forum.reallusion.com/uploads/images/2666f30c-597c-477c-aef8-7dee.jpgre any way to scale the interface? the text and icons are way too big. Makes the software look cheap lol. It's not... All I found was a greyed out box in preferences
Yo Dojo
Yo Dojo
I guess there is an icon size in iclone. Pick one of three. That helped a little. Character creator doesn't have the same option it seems
For 4k monitors, check the Scale for the Windows Display settings. (Right-click the desktop and select "Display settings".)
It may be set at to high a value. (The default is 300%, which is crazy.) I've set it 125% on my 4k monitor and that works fine.
Ironically, things may now be too small.
To fix that, Right-click the iClone desktop icon and select Properties and then click the Compatibility tab. Once there, click Change high DPI settings.
At the pop-up that opens, go to the High DPI scaling override, click the check mark and select System (Enhanced) from the drop-down.
rogyru
rogyru
Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)
Posts: 497, Visits: 1.3K
Disappointed to say the least no improvements at all in the UI in Iclone 8 for 4k displays .They some how managed to make it even worse on 4K displays. The content bar can't be resized and takes up almost 40% of the screen . And the solution animagic posted is no use as any other program you use will have tiny text in it and no the default 300 is not crazy its standard on large 4k displays. I have no such problems when i use Unreal engine . Iclone UI scaling and options are old
https://forum.reallusion.com/uploads/images/82805bc5-6cde-4941-9ffd-a0c3.png
I'm sorry my suggestion didn't work for you. I use the 125% scaling with all my graphics intensive programs, including After Effects, Photoshop, Vegas Pro, etc.
Beyondcomm
Beyondcomm
New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)New Member (80 reputation)
Posts: 4, Visits: 24
I have the same problem. I bought a 4k monitor thinking it would save space, but iClone doesn't adapt the size of the interface. It's a very amateurish mistake.
Beyondcomm (10/19/2024)
The advice given by animagic earlier in this thread should work for you. I've used iClone 8 and CC4 on various screens ranging from QHD to full 4K and the method shown has always worked.
