UE5 & Reallusion - Tips & Tricks
Posted By StyleMarshal 5 Years Ago
445
446
447
448
449
473
inash
inash
Posts: 46, Visits: 775
Question. Does the "Apply CC Textures" feature in Unreal Engine work ONLY for the custom metahuman you just imported/created or can it be applied to any Metahuman
I'm asking because I've made a custom Metahuman with CC4 Morphs using Faceform Wrap and Metapipe. And I'd love to apply the textures from the CC4 Model that the morph was created with, directly to the Metahuman version.  If not, I guess I'll have to finish creating the CC4 Metahuman and then transfer the textures to the Metapipe version.
Thanks
___________________________________________
Graphic Designer / Video Editor / Sound Engineer
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-4930K 3.4 GHZ / MB: ASUS Sabertooth X79 /  RAM: 32GB G-SKILL RIPJAW / HD: 2TB+2TB+3TB  /  SSD: 256 Samsung 860 EVO & 128 Samsung 860 EVO/
GPU: GTX 1080 Ti 11GB / COOLER : CORSAIR H75 Liquid Cooler
StyleMarshal
StyleMarshal
Posts: 5.8K, Visits: 14.3K
inash (7/2/2024)
Thanks
Should work as long as you haven't changed the UVs
hoodtronik
hoodtronik
Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)
Posts: 46, Visits: 299
Bassline303 (7/2/2024)
inash (7/2/2024)
Thanks
Thanks Bassline!
Reallusion Support just sent me this "With the plugin, you can only apply to the Metahuman with the name you created for your Metahuman Identity. But once you have the textures, you should be able to swap them with other Metahumans, since all Metahumans have the UV." I'm still going to tinker and try experimenting with the names, etc. to see if there is a more direct way. But at least I know a path forward. Thanks as always!
oberdoofus
oberdoofus
Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)
Posts: 116, Visits: 3.1K
Hi Has anyone run into this issue before? I have a CC3 character with stylized (largeish) eyes. In CC it looks fine but when i import to unreal (UE5.3) I can see through his head all the way to the horizon!
I've tried tweaking the inner eye with sliders (headshot) with a little success, converting the headskin into two-sided, i suppose i could push the eyes out a bit with EyeBall depth sliders or using edit Mesh(?) - but really I'm just curious why it seems to look fine in CC but when I export to UE that section of the eyes appears to disappear? Especially since i don't recall this being an issue with similar characters before. (Might it be something to do with them being a little old? - originally made for UE 5.0 and migrated to 5.3? I also recently updated autosetup, so replaced CC Shaders with a new version and also added the CC ControlRig plugin FWIW)
As always, any help much appreciated!
UPDATE
I ended up fixing the inner eye using CC sliders to hide the gaps but still curious as to why the problem emerged in the first place!
Anyone doing big stylized eyes run into similar issues?
make.snsd.mv
make.snsd.mv
Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)
Posts: 54, Visits: 440
thanks Boss
I try to bring the character with hairs if we use this method, the hairs polygons will be too many for physics simulation
StyleMarshal
StyleMarshal
oberdoofus (7/4/2024)
UPDATE
it is hard to say without seeing the shader but it looks like the "lacrimal / Caruncle"  is miising or has a wrong shader ( translucent ? )
https://forum.reallusion.com/uploads/images/528bcd99-0e6c-45b0-ac10-8bd5.jpg
https://forum.reallusion.com/uploads/images/ff9cbe09-1e26-4480-98b7-73e0.jpg
https://forum.reallusion.com/uploads/images/9d98ca10-e4ca-40fd-9bb7-b385.jpg
https://forum.reallusion.com/uploads/images/5ed9f188-8e9a-4c0b-97cb-1c0b.gif
oberdoofus
oberdoofus
@bassline
Thanks Bass - as always - you da man! Will check it out.
OB1Flow
OB1Flow
Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)
Posts: 44, Visits: 222
Is there a quick way to locate a livelink character from iclone to a specific spot on the unreal map?  Currently I'm offsetting the location inside iclone but that alters the anim.
StyleMarshal
StyleMarshal
OB1Flow (7/7/2024)
Hey dude , how is it going?  😁
Add a Live Link Origin , place it in the scene, parent the CC Character under it and zero out the CC Character. Now you can use the Origin to place the Character where ever you want.
https://forum.reallusion.com/uploads/images/a61acc66-6f52-4f7a-bd5f-f1e6.jpg
You can also use an "Empty Actor" works the same :
https://forum.reallusion.com/uploads/images/32d8cf91-4175-446e-898e-251c.jpg
OB1Flow
OB1Flow
Thanks!  Just playing around again, I'll give this a shot.
445
446
447
448
449
473
