carmagnacjulien
carmagnacjulien
Visits: 21
Hello, I buy the Athletic Run pack for iClone but I realize that is only be used with controller and all the motion director stuff. Can you tell me how can I extract and apply individually a simple looping motion from this pack to my character ? Thank you, Julien
Hi Julien The Athletic Run pack is designed for Motion Director and doesn't come with standard motion files in rlMotion format. However, you can record the Athletic Run animation in Motion Director and then use the "Collect Clip" feature on the Timeline to save the recorded animation to .rlMotion which can then be applied to any character just like a standard motion clip.
carmagnacjulien
carmagnacjulien
Visits: 21
Hello Peter,
Thank you for your response. Can you explain me the best steps to do this ? I'm new to this sofware and I may admit that I'm a bit lost.
How can I put one motion, run for example, and played it straight without any interaction input ?
Thanks, Julien
If you need help with Motion Director, then please check out the tutorials available below. I would recommend watching the "Getting Started" tutorial at a minimum.
https://courses.reallusion.com/home/iclone/motion-director
Once you understand how to use Motion Director you can record animation using the Athletic Run pack and save those animations as standard .rlMotion files. These saved motion clips can then be applied to any character. To find out how to save the Motion Director data to a motion clip, please see the "Collect Clip" section of the manual below.
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/51-Animation-Timeline-Editing/Collect_Clip_Track.htm
