michael_571550
michael_571550
Visits: 331
Hi - I am experience the same animation import settings problem
Is there any workaround for now? Any ETA on the fix?
Thanks
Visits: 86
The workaround is to switch back to 1.01 :-)
Visits: 407
Hi, The tool actually impact FBX that I import in my project even though they are not Iclone/CC related and are not imported in the CC Asset folder.
The tool is touching things it should not, I hope you can fix that soon
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Necka (6/29/2020) Hi, The tool actually impact FBX that I import in my project even though they are not Iclone/CC related and are not imported in the CC Asset folder.
The tool is touching things it should not, I hope you can fix that soonHi Necka! It's fixed in version 1.1. Please download the tool, and try again, thank you! https://www.reallusion.com/character-creator/unity-auto-setup.html
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
sabrx (6/27/2020) The workaround is to switch back to 1.01 :-)
Hi sabrx, michael and others, It's fixed in version 1.1. Please download the tool, and try again, thank you!
bmacdonald1986
bmacdonald1986
Visits: 123
Hi Miranda, was this problem ever resolved? I am having similar issues now with modifying animations to loop in Unity. When you apply the settings to the FBX import, the settings are reverted to the import default (no looping).
Thanks
Visits: 86
I can confirm that version 1.1 works flawlessly in Unity 2019.3.13f1. Maybe you have Auto-processing enabled during the editing. You better disable it and then do the changes.
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
May you double check the settings that sabrx mentioned? Open the Settings panel (Tools menu > Character Creator & iClone Auto Setup) to make sure the "Auto-Processing" option is unchecked.
