The following problem occurred...The following problem occurred...
Threaded View
Threaded View
Forum Post iClone 6 viewport VS iClone 6 render By R.Man ( 10 Years Ago )
Forum Post I did some tests and I can confirm that the DOF in the view port is... By animagic ( 10 Years Ago )
Forum Post Yes i've noticed it in previous version of IC6 but i didn't pay much... By R.Man ( 10 Years Ago )
Forum Post I reported this as a bug in the (long) iClone 6.3 bug thread and folks... By Kelleytoons ( 10 Years Ago )
Forum Post So what user supposed to do? If it's not a bug? I can't even export... By R.Man ( 10 Years Ago )
Forum Post I would say DOF in iC6 has a few bugs. I contend, as I have mentioned... By mark ( 10 Years Ago )
Forum Post Looking at some previous renders this morning, I guess I never really... By animagic ( 10 Years Ago )
Forum Post I can understand some differences between "Real Time" and "Render."... By justaviking ( 10 Years Ago )
Forum Post JV, It's VERY different -- if examples posted here aren't enough I... By Kelleytoons ( 10 Years Ago )
Forum Post [quote][b]Kelleytoons (1/7/2016)[/b][hr]JV, It's VERY... By justaviking ( 10 Years Ago )
Forum Post I don't use the preview so we'll have to let the OP speak for... By Kelleytoons ( 10 Years Ago )
Forum Post Hi, I'm a newbie here, I hope you don't mind me replying to a slightly... By kristiinakello ( 10 Years Ago )
Forum Post Have you tried adjusting your Focal Range once the Item you want is... By Cricky ( 10 Years Ago )
Forum Post [quote][b]justaviking (1/7/2016)[/b][hr]We have three things, right?... By animagic ( 10 Years Ago )
Forum Post [quote][b]animagic (1/7/2016)[/b][hr][quote][b]justaviking... By justaviking ( 10 Years Ago )
Forum Post [quote][b]Kelleytoons (1/7/2016)[/b][hr]JV, It's VERY different -- if... By urbanlamb ( 10 Years Ago )
Forum Post Also try setting it to "Preview" instead of "Final Render". The... By Rampa ( 10 Years Ago )
Forum Post Also try setting the output to "Preview" instead of "Final Render". I... By Rampa ( 10 Years Ago )
Forum Post Cricky and Rampa, thanks for the replies! Cricky, dropping focal... By kristiinakello ( 10 Years Ago )
Forum Post Have you tried Hardware Video Encoder Rendering as an option to... By Cricky ( 10 Years Ago )
Forum Post You may also get different levels of apparent DOF rendering as image... By Rampa ( 10 Years Ago )
Forum Post Just a triple rendering using iClone6 DOF for comparisons.... By Cricky ( 10 Years Ago )
Forum Post I had the time to try IC7 , i think that the problem is still here... By R.Man ( 9 Years Ago )
