laughingcrows
laughingcrows
Posted 16 Years Ago
Last Active: 15 Years Ago
Visits: 152
Just checking, it's been almost a year now since you released Iclone 3 with the following statement about Zbrush. Use Zbrush to generate normal maps with the iClone 3 actor templates allow you to create actors with wrinkles or better body definition and muscle tone. If you are not going to release the actor templates for Zbrush users, please just tell me. I've kept hope up this whole time, please don't let us down. Thank you.
Posted 16 Years Ago
Hi LC, Apologies for the long delay in updates on this situation. I will get the latest on the ZBrush templates and let you know here as soon as I find out anything.
Illustrator Cathy
Illustrator Cathy
Posted 16 Years Ago
Last Active: 10 Years Ago
Visits: 1.7K
This is interesting. I too would like to know more about this. Cathy :hehe:
Just click on the graphic to go there.
Posted 16 Years Ago
A ZBrush Pipeline Guide/White Paper was just published ( http://developer.reallusion.com/whitepaper/Zbrush_Pipeline/index.htm). Does that have any bearing on the topic? Also, it wasn't clear from that guide if ZBrush could be used without 3DS Max. I assume for maps you could.
laughingcrows
laughingcrows
Posted 16 Years Ago
Visits: 152
Peter Edwards (7/7/2009) Hi LC,
Apologies for the long delay in updates on this situation. I will get the latest on the ZBrush templates and let you know here as soon as I find out anything.Thank you for responding Mr. Edwards, l hope this is resolved soon.
Posted 16 Years Ago
Hi LC, The ZBrush OBJ files and Whitepaper are now available to download from the Developer Center. For your convenience I've included the links below. Whitepaper ZBrush Materials The downside to this release is that currently you will need 3DS Max and the plugin to export your new ZBrush created head into iClone. This should change with the release of 3DXchange 3.0. Thanks for your patience during the long delay getting these files released. We appreciate you hanging in there all this time.
Illustrator Cathy
Illustrator Cathy
Posted 16 Years Ago
Visits: 1.7K
OOOH!! 3D Exchange 3.0?!??! How exciting! Will we be able to export .vns to .obj? Cathy :w00t:
cortes_will
cortes_will
Posted 16 Years Ago
Visits: 170
Do you need Zbrush 3.0? What limitations do I have with using Zbrush 2.0?
Sen
Last Active: 6 Months Ago
Posts: 2.8K,
Visits: 28.5K
Hi , no Zmapper . but nothing insurmountable because one can nevertheless create normal map and displace map . Tools > normal map or displacement . Normaly , the brush” move” in ZB 3.1 correspond to the brush "tweak" ;) .
CGTRADER
cortes_will
cortes_will
Posted 16 Years Ago
Visits: 170
Great..so I can follow the tutorial that iclone has on using Zbrush w/o aproblem?
