Exporting Iclone to 3ds max
Posted By mailtophoo 11 Years Ago
mailtophoo
Crazy
mailtophoo
Posted 11 Years Ago
Veteran Member (703 reputation)Veteran Member (703 reputation)Veteran Member (703 reputation)Veteran Member (703 reputation)Veteran Member (703 reputation)Veteran Member (703 reputation)Veteran Member (703 reputation)Veteran Member (703 reputation)Veteran Member (703 reputation)
Last Active: 10 Years Ago
Posts: 53, Visits: 314
hello there friends,
I want to export iclone character to 3ds max via FBX and followed some tutorials like "https://www.youtube.com/watch?v=pX40UbdMhiQ" but at the very end i found i could not export where the tool preset in 3dxchange(please view the attachment filled with red circle) for exporting to 3ds max cannot be found. Please help how can i get over there.
Phoo
planetstardragon
planetstardragon
Posted 11 Years Ago
Last Active: 3 days ago
Posts: 11.5K, Visits: 46.0K
Hi mailtophoo :)/
with the assumption that you have the "pipeline" version of 3Dxchange ( because it's the only version that exports fbx ) - it's strange that you do not have that preset because it's automatically installed in your system with the software - aside from just assuming that your installation is missing files, thus may need a fresh installation, do you have the latest updates installed - as that may be a factor.
Cheers!
planetstardragon
planetstardragon
Posted 11 Years Ago
eep, scratch that , I just fired up my software to verify - and i didn't have it either lol - that graphic is also from the beta version..... try the motionbuilder or maya - it should still be compatible - you can also customize the options as well. - I'm sure it will work fine else this forum would have been in an uproar since most of the top developers use max. ;)
Vit3D
Vit3D
Posted 11 Years Ago
Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)
Posts: 917, Visits: 15.1K
Hi mailtophoo,
The only important difference between Max and Maya presets is that for Maya Axis settings is "Y-Up" but for Max You should use "Z-Up" for this parameters.
All other parameters depends from Your needs.
Tip: To improve textures quality after export is better to set check mark in parameter "Convert Image Format to" and change it to something different from JPG ;)
Good Luck :)
Vit
mailtophoo
mailtophoo
Posted 11 Years Ago
Hello friend
don't know why this happend only to my machine could not work out finding for more solution.
Phoo
Posted 11 Years Ago
The 3DS Max preset is available in 3DXchange5 Pipeline 5.51. Please make sure you have installed the latest full version. You can get this from your Member Account.
You will then see the options below.
planetstardragon
planetstardragon
Posted 11 Years Ago
Hi Peter,
I just double checked mine, and it's not showing, i'm on the latest version.
Sen
Sen
Posted 11 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Posts: 2.8K, Visits: 28.5K
Like Vitaly said , you don't need any profil to export max or other . Just choose what you want .
3dx5.51 show some preset , yes , but what if you don't know what is checked :P .
CGTRADER
