HooDooPhonix
HooDooPhonix
Visits: 95
luciano this is great but i dont see the same lables inside the geomtery edtor or when i right click. could you do a tutoria video maybe??
imranazeb
imranazeb
Visits: 32
Select genesis 8.1 character root. Go to Tools>Joint Editor. Make sure the root is selected in the scene section and not hip, pelvis etc. Right click in the view port, select edit>rename node. Change the text in Node name from Genesis8_1Female to Genesis8Female. Everything should work fine now.
Visits: 22.1K
Here's a video:
animatedbeing
animatedbeing
Last Active: 3 Weeks Ago
Visits: 1.8K
LFA (6/19/2021)
Hi Mike, Forgive me if I am misunderstanding terminology. What I mean by "G81 morphs" is the basic shape of a g81 figure. This one below is Jacqueline 81 transferred over CC3 by just renaming the root node and root label, and not baking textures. This time, I didn't add a G8 figure in the scene, that was a deprecated method. I will PM you. Best regards, Luciano 27% of original size (was 1920x1080) - Click to enlarge The image does not show the torso, which is the map that does not transfer. But just renaming the node does make the process simple for characters in which the upper body is covered.
animatedbeing
animatedbeing
Visits: 1.8K
Has anyone had luck getting the eyelashes parented to the figure? 27% of original size (was 1920x1080) - Click to enlarge
Visits: 22.1K
You will need to use the CC eyebrows.
animatedbeing
animatedbeing
Visits: 1.8K
Kelleytoons (9/8/2022) You will need to use the CC eyebrows.The character has brows. The 8.1 lashes are imported separately and I can't get them parented. I even renamed the node to Genesis8FemaleEyelashes. Trying to add CC lashes does not work.
animatedbeing
animatedbeing
Visits: 1.8K
Just for fun lashes saved as brows - Genesis8FemaleEyelashes 27% of original size (was 1920x1080) - Click to enlarge
Visits: 22.1K
You need to delete them. Again, you cannot use 8.1 lashes on a CC avatar.
LFA
Visits: 243
Hi there, You want to select the 8.1 figure and apply a genesis 8 female eyelashes. Delete 8.1 eyelashes and tear. That should work.
