Daz Genesis 8.1 import issue
Posted By zaoeyo 4 Years Ago
3
4
5
6
7
tamulur
tamulur
Junior Member (128 reputation)Junior Member (128 reputation)Junior Member (128 reputation)Junior Member (128 reputation)Junior Member (128 reputation)Junior Member (128 reputation)Junior Member (128 reputation)Junior Member (128 reputation)Junior Member (128 reputation)
Posts: 9, Visits: 414
That looks pretty good. Do the eyelashes match that well also when the eyes are open?
Could you post which blendshapes you changed and how much?
animatedbeing
animatedbeing
Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)
Posts: 114, Visits: 1.8K
LFA (9/8/2022)
Hi there,
You want to select the 8.1 figure and apply a genesis 8 female eyelashes. Delete 8.1 eyelashes and tear. That should work.
Thanks. That worked.
Note I corrected the eyeblink and did some eyelash slider corrections for the figure in the image below.
84% of original size (was 602x204) - Click to enlarge
animatedbeing
animatedbeing
LFA (9/8/2022)
Hi there,
Thanks that worked.
LFA
LFA
Senior Member (357 reputation)Senior Member (357 reputation)Senior Member (357 reputation)Senior Member (357 reputation)Senior Member (357 reputation)Senior Member (357 reputation)Senior Member (357 reputation)Senior Member (357 reputation)Senior Member (357 reputation)
Posts: 36, Visits: 243
Hi there,
Posts: 9.2K, Visits: 22.1K
You need to delete them.  Again, you cannot use 8.1 lashes on a CC avatar.
animatedbeing
animatedbeing
Just for fun lashes saved as brows - Genesis8FemaleEyelashes
animatedbeing
animatedbeing
Kelleytoons (9/8/2022)
You will need to use the CC eyebrows.
The character has brows. The 8.1 lashes are imported separately and I can't get them parented. I even renamed the node to Genesis8FemaleEyelashes. Trying to add CC lashes does not work.
animatedbeing
animatedbeing
Has anyone had luck getting the eyelashes parented to the figure?
animatedbeing
animatedbeing
LFA (6/19/2021)
Hi Mike,
Forgive me if I am misunderstanding terminology. What I mean by "G81 morphs" is the basic shape of a g81 figure. This one below is Jacqueline 81 transferred over CC3 by just renaming the root node and root label, and not baking textures.
This time, I didn't add a G8 figure in the scene, that was a deprecated method.
I will PM you.
Best regards,
Luciano
The image does not show the torso, which is the map that does not transfer. But just renaming the node does make the process simple for characters in which the upper body is covered.
3
4
5
6
7
