Minnie (RL)
Minnie (RL)
Group: Moderators
Visits: 913
01. Installation Instruction & Download ResourcesIn order to maintain proper operation of your installed applications (Cartoon Animator, Motion Live 2D Plugin, and iClone); we will provide you with Early Access applications in the form of zip files. You can then run Early Access applications independently. Please read the following post carefully before installing the programs and plug-ins.
AP & Content Files (For Early Access Only, expired after Dec. 10th)- CTA 4.4 Software
- CTA4.4_Beta.zip (280 MB)
** Notice: Updated on Nov 19th. For those who don't have Motion Live 2D Plug-in previously, the updated version has the plug-in pre-installed in the software. - MotionLink.reg (3KB)
- Cartoon Animator Motion Link Plugin for Iclone 7.8
- Content Pack for Cartoon Animator 4.4
- Your creations during this Early Access program will NOT be compatible with the official version. If you are trying out this version for a project, please use this early access version from start to finish.
- You should stay away from running this CTA 4.4 early access program along with your current official CTA software at the same time.
- You have to update your iClone to version 7.8, in order to run this program.
- The Early Access program will expire on December 9th, 2020. However, all projects created with this program can still be used when the official version comes out.
- If you don't have iClone, you still can try the new updates of 3D Motion Converter in CTA.
>> Check here for the introduction of 3D Motion Converter.
Installation Guide & Content Resource
FAQ
1. What is Motion Live 2D and Why do I need it? Motion LIVE 2D is a plug-in for Cartoon Animator to Control an array of mocap gear with real-time animation Link to iClone to further real-time edit your 3D motion to 2D Character. (NEW!) In order to link to iClone for motion creation and editing, you will have to install this Motion Live 2D Plug-in under Cartoon Animator. 2. What is iClone Motion Link Plugin and Why do I need it? Motion Link is a plug-in for iClone to send real-time motion editing data to 2D characters in Cartoon Animator. In order to link to Cartoon Animator, you will have to install Motion Link plug-in for iClone.
Minnie (RL)
Minnie (RL)
Group: Moderators
Visits: 913
How to launch Cartoon Animator v4.4 Early Access Version:- Please make sure you have installed the official Cartoon Animator 4.0.
- Please make sure you have closed the official Cartoon Animator 4.0.
- Unzip the “CTA4.4_Beta.zip” file.
- Go to the “~\CTA4.4_Beta\bin64\”.
How to enable the Motion Link Profile in Motion LIVE 2D:
Minnie (RL)
Minnie (RL)
Group: Moderators
Visits: 913
01- 2 Installation (iClone - Motion Link)
Go to the “Bin64\OpenPlugin” and paste the “MotionLink” folder.
How to activate Motion Link?
Execute the “~\CTA4.4_Beta\bin64\CartoonAnimator.exe” Load a character from the Content Manager. Select top menu / Plugins / Motion LIVE 2D.
- Connect the iClone Motion Link. (Green light means successful).
- iClone started streaming motion data to Cartoon Animator.
creativeashok
creativeashok
Visits: 151
Hi All, I followed the steps but MOTION LIVE 2D plugin not showing in my CTA 4.4
kylelee
kylelee
Visits: 4.2K
Please help me to confirm the below things: 1. Download the Beta v2 (11/19 version), we have updated the beta version on 11/19. 2. Execute the Motionlink.reg https://forum.reallusion.com/FindPost463874.aspx
Minnie (RL)
Minnie (RL)
Group: Moderators
Visits: 913
02 How to Add and Find Embedded Content
1) Launch CTA 4.4 program
2) Hover the mouse over any content item on Content Manager Panel, and right click to “Find File”
3) Go back to “Cartoon Animator 4 Template”
4) Unzip “CTA4.4_BetaContent_v2” compressed folder 5) Launch “CTA4.4_BetaContent_v2" folder and open “Content” folder 6) Copy all folders and Paste to “Cartoon Animator 4 Template" folder
Where to find your new content:
rfbindl
rfbindl
Visits: 1.4K
I downloaded the 3 zip files earlier today but can't find a file MotionLink.reg in any of the 3 unzipped folders. I searched all 3 folders but no *.reg or MotionLink.reg file found. Can I get it another way?
CTA4.4_Beta_v2 CTA4.4_BetaContent_v2 iClone_MotionLink_plugin
I'm also curious about the instructions word to "terminate". I take it to mean turn off CTA so it's not running, not uninstall. It sounds more final... like uninstall.
DanielC_RL
DanielC_RL
Visits: 646
You can download MotionLink.reg by clicking on the link text just like you download the other zip files, please see the attached screenshot.
and regarding the meaning of terminate, we will think about whether there is a better description, thank you for your suggestions !
Hope you can have a pleasant experience !
Daniel
jazzsinger56
jazzsinger56
Visits: 169
Hi, I'm confused, guys. I have done everything correctly (I think). but when I try to connect iClone to CA4 the "body" in CA4 is greyed out so I cannot select it. Please see the image attached. I updated everything, iClone, CA4 (not beta) and all my plugins. I installed the .reg file and copied the motion live folder into iclone. Everything should be fine. Does anyone have any idea what's going on, please? Thanks, Cheryl
kylelee
kylelee
Visits: 4.2K
jazzsinger56 (11/26/2020)
Hi, I'm confused, guys. I have done everything correctly (I think). but when I try to connect iClone to CA4 the "body" in CA4 is greyed out so I cannot select it. Please see the image attached. I updated everything, iClone, CA4 (not beta) and all my plugins. I installed the .reg file and copied the motion live folder into iclone. Everything should be fine. Does anyone have any idea what's going on, please? Thanks, Cheryl  Please refer this post video around 2:59. You have to assign the gear to character in the Motion LIVE 2D. https://forum.reallusion.com/FindPost463259.aspx
