By Minnie (RL) - 6 Years Ago
01. Installation Instruction & Download ResourcesIn order to maintain proper operation of your installed applications (Cartoon Animator, Motion Live 2D Plugin, and iClone); we will provide you with Early Access applications in the form of zip files. You can then run Early Access applications independently. Please read the following post carefully before installing the programs and plug-ins.
AP & Content Files (For Early Access Only, expired after Dec. 10th)- CTA 4.4 Software
- CTA4.4_Beta.zip (280 MB)
** Notice: Updated on Nov 19th. For those who don't have Motion Live 2D Plug-in previously, the updated version has the plug-in pre-installed in the software. - MotionLink.reg (3KB)
- Cartoon Animator Motion Link Plugin for Iclone 7.8
- Content Pack for Cartoon Animator 4.4
- Your creations during this Early Access program will NOT be compatible with the official version. If you are trying out this version for a project, please use this early access version from start to finish.
- You should stay away from running this CTA 4.4 early access program along with your current official CTA software at the same time.
- You have to update your iClone to version 7.8, in order to run this program.
- The Early Access program will expire on December 9th, 2020. However, all projects created with this program can still be used when the official version comes out.
- If you don't have iClone, you still can try the new updates of 3D Motion Converter in CTA.
>> Check here for the introduction of 3D Motion Converter.
Installation Guide & Content Resource
FAQ
1. What is Motion Live 2D and Why do I need it? Motion LIVE 2D is a plug-in for Cartoon Animator to Control an array of mocap gear with real-time animation Link to iClone to further real-time edit your 3D motion to 2D Character. (NEW!) In order to link to iClone for motion creation and editing, you will have to install this Motion Live 2D Plug-in under Cartoon Animator. 2. What is iClone Motion Link Plugin and Why do I need it? Motion Link is a plug-in for iClone to send real-time motion editing data to 2D characters in Cartoon Animator. In order to link to Cartoon Animator, you will have to install Motion Link plug-in for iClone.
How to launch Cartoon Animator v4.4 Early Access Version:- Please make sure you have installed the official Cartoon Animator 4.0.
- Please make sure you have closed the official Cartoon Animator 4.0.
- Unzip the “CTA4.4_Beta.zip” file.
- Go to the “~\CTA4.4_Beta\bin64\”.
How to enable the Motion Link Profile in Motion LIVE 2D:
01- 2 Installation (iClone - Motion Link)
Go to the “Bin64\OpenPlugin” and paste the “MotionLink” folder.
How to activate Motion Link?
Execute the “~\CTA4.4_Beta\bin64\CartoonAnimator.exe” Load a character from the Content Manager. Select top menu / Plugins / Motion LIVE 2D.
- Connect the iClone Motion Link. (Green light means successful).
- iClone started streaming motion data to Cartoon Animator.
By creativeashok - 6 Years Ago
Hi All, I followed the steps but MOTION LIVE 2D plugin not showing in my CTA 4.4
By kylelee - 6 Years Ago
Please help me to confirm the below things: 1. Download the Beta v2 (11/19 version), we have updated the beta version on 11/19. 2. Execute the Motionlink.reg https://forum.reallusion.com/FindPost463874.aspx
02 How to Add and Find Embedded Content
1) Launch CTA 4.4 program
2) Hover the mouse over any content item on Content Manager Panel, and right click to “Find File”
3) Go back to “Cartoon Animator 4 Template”
4) Unzip “CTA4.4_BetaContent_v2” compressed folder 5) Launch “CTA4.4_BetaContent_v2" folder and open “Content” folder 6) Copy all folders and Paste to “Cartoon Animator 4 Template" folder
Where to find your new content:
By rfbindl - 6 Years Ago
I downloaded the 3 zip files earlier today but can't find a file MotionLink.reg in any of the 3 unzipped folders. I searched all 3 folders but no *.reg or MotionLink.reg file found. Can I get it another way?
CTA4.4_Beta_v2 CTA4.4_BetaContent_v2 iClone_MotionLink_plugin
I'm also curious about the instructions word to "terminate". I take it to mean turn off CTA so it's not running, not uninstall. It sounds more final... like uninstall.
By DanielC_RL - 6 Years Ago
You can download MotionLink.reg by clicking on the link text just like you download the other zip files, please see the attached screenshot.
and regarding the meaning of terminate, we will think about whether there is a better description, thank you for your suggestions !
Hope you can have a pleasant experience !
Daniel
By jazzsinger56 - 6 Years Ago
Hi, I'm confused, guys. I have done everything correctly (I think). but when I try to connect iClone to CA4 the "body" in CA4 is greyed out so I cannot select it. Please see the image attached.
I updated everything, iClone, CA4 (not beta) and all my plugins. I installed the .reg file and copied the motion live folder into iclone. Everything should be fine.
Does anyone have any idea what's going on, please?
Thanks, Cheryl
jazzsinger56 (11/26/2020)
Hi, I'm confused, guys. I have done everything correctly (I think). but when I try to connect iClone to CA4 the "body" in CA4 is greyed out so I cannot select it. Please see the image attached. I updated everything, iClone, CA4 (not beta) and all my plugins. I installed the .reg file and copied the motion live folder into iclone. Everything should be fine. Does anyone have any idea what's going on, please? Thanks, Cheryl
Please refer this post video around 2:59. You have to assign the gear to character in the Motion LIVE 2D. https://forum.reallusion.com/FindPost463259.aspx
Thanks Daniel. I'm knocking myself on the head wondering how I missed it. It won't, however, be the first time I was blind to seeing things in front of my nose. ;) Not sure how I could have missed it. Whoops. Roger
DanielC_RL (11/26/2020)
Daniel
Thanks, mate. I'd have sworn I did that, but apparently not!! Thanks for your help, Cheryl
By GADEL - 6 Years Ago
I have followed the instructions and so far everything seems to be working well at my end.
By feelingood - 6 Years Ago
Hi, "and regarding the meaning of terminate, we will think about whether there is a better description, thank you for your suggestions !" The word "terminate" creates a confusion, which could mean uninstall. I would suggest the terms "Close", "Close down", "Shut down", "make sure it's not running",or similar. I hope that it helps. Cheers :-)
@rfbindl @feelingood
Thank you both for the suggestion, I've changed the terms "terminate" to avoid confusion. Thanks again :)
By chrismattos - 6 Years Ago
I followed all instructions. when I open the cartoon animator program, I get the following messages:
By vepop - 6 Years Ago
Where to download the 3D Motion Converter? For those who do not own I-Clone, what programs to install in order to participate?
chrismattos (11/29/2020)
@chrismattos
Face3D profile does not effect the functionality of Motion Link, you can click on "OK" to proceed.
@vepop
3D Motion Converter is an embedded feature in the new version of CTA, you can directly download CTA4.4_Beta.zip (280 MB) to try 3D motion converter.
Thanks Minnie for the response.
After I executed "CartoonAnimator.exe", the logo (ver.4.3) appeared but the program did not open. Is this normal? Should I proceed to the next step? . *Update* I proceeded to the next step. Double clicked the 'MotionLink'. Once done, I double clicked "'CartoonAnimator.exe" again. Program did not open.
@vepop
Would you kindly record your screen (instead of some screenshots, for this issue, would be more informative with a recorded video) for us to look into it. Much appreciated.
Here is the vid (unlisted):-
By andre_528119 - 6 Years Ago
Just a typo to correct in the last section of the tutorial on how to link iClone with Cartoon Animator: "Sync to Cartoon Animator" should read "Send to Cartoon Animator".
Any solution to this problem?
After two days, there is still no response. Why?
@vepop
Sorry for the delayed response, but we are currently working on it and troubleshoot this issue. Thanks for the patience and sorry again for the inconvenience.
@andre_528119]
Thank you very much. the text has been changed :)
I have the same problem, still unsolved. Apparently the tech. support is working on it. It maybe a conflict with the existing CA4.3, but it's not confirmed.
