In order to maintain proper operation of your installed applications (Cartoon Animator, Motion Live 2D Plugin, and iClone);
we will provide you with Early Access applications in the form of zip files.
You can then run Early Access applications independently.
Please read the following post carefully before installing the programs and plug-ins.
AP & Content Files (For Early Access Only, expired after Dec. 10th)- CTA 4.4 Software
- CTA4.4_Beta.zip (280 MB)
** Notice: Updated on Nov 19th. For those who don't have Motion Live 2D Plug-in previously, the updated version has the plug-in pre-installed in the software. - MotionLink.reg (3KB)
- Cartoon Animator Motion Link Plugin for Iclone 7.8
- Content Pack for Cartoon Animator 4.4
- Your creations during this Early Access program will NOT be compatible with the official version. If you are trying out this version for a project, please use this early access version from start to finish.
- You should stay away from running this CTA 4.4 early access program along with your current official CTA software at the same time.
- You have to update your iClone to version 7.8, in order to run this program.
- The Early Access program will expire on December 9th, 2020. However, all projects created with this program can still be used when the official version comes out.
- If you don't have iClone, you still can try the new updates of 3D Motion Converter in CTA.
>> Check here for the introduction of 3D Motion Converter.
Installation Guide & Content Resource
FAQ
1. What is Motion Live 2D and Why do I need it?
Motion LIVE 2D is a plug-in for Cartoon Animator to
Control an array of mocap gear with real-time animation
Link to iClone to further real-time edit your 3D motion to 2D Character. (NEW!)
In order to link to iClone for motion creation and editing, you will have to install this Motion Live 2D Plug-in under Cartoon Animator.
2. What is iClone Motion Link Plugin and Why do I need it?
Motion Link is a plug-in for iClone to send real-time motion editing data to 2D characters in Cartoon Animator. In order to link to Cartoon Animator, you will have to install Motion Link plug-in for iClone.
