mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Hi , I have often this problem when trying to convert to non-standard character...
You can download the creature with this link: https://www.dropbox.com/s/5d2q1uzt62jjzr0/BLISS.zip?dl=0Thank you
Last Active: 5 hours ago
Visits: 62.6K
I think you solved it yourself. Set the forward offset to zero as you were doing, and then check the Active box.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Thank you Rampa but I tried it and didn't fix it. I reupload the creature in Iclone format : https://www.dropbox.com/s/b70gfars45vg9ib/Blissp.7z?dl=0
tripfreak
tripfreak
Posts: 2.0K,
Visits: 2.8K
I'm afraid there is not much you can do, because in 3DX the problem already starts from the beginning:  But nonetheless, thanx for bliss!
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Hahhaha! cool! Sorry for the wrong file , here is the good one. Same issue https://www.dropbox.com/s/rnlglv4rgcr63uh/VAA.7z?dl=0
Posts: 5.3K,
Visits: 16.8K
It'd be nice if you also provide .3DXprofile file for the last fbx, so we do not have to guess bones all over :)
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Posts: 5.3K,
Visits: 16.8K
OK, I fixed him a bit in Blender (removed double vertices which were causing problem and scaled that little calf bone). You may need to reapply texture as I think it's linked from my computer. https://www.dropbox.com/s/sp4dya5kujfhjdc/BlisspVAA_fixed.zip?dl=0 But ideally the feet mesh should be joint with legs and better weight painted so that there is no jagged border in between them.
matenn30
matenn30
Visits: 3.3K
Will this be put out in the market place? If you put it out, I want to appreciate it. これは、market placeに出しますか。もし出す場合、鑑賞したいです。
The forum is an amateur. フォーラムは素人です。
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Wow! Thank you 4u2ges. It works perfectly. unfortunately it is too advanced for me what you explain. I should see a tutorial because I have this kind of problem very often, I use a lot of creatures with non-human postures. if you have a little time to show it even without audio it would be cool :D
