3DXchange activate issue
Posted By mtakerkart 6 Years Ago
mtakerkart
mtakerkart
Posts: 3.2K, Visits: 29.2K
Hi ,
I have often this problem when trying to convert to non-standard character...
You can download the creature with this link:
https://www.dropbox.com/s/5d2q1uzt62jjzr0/BLISS.zip?dl=0
Thank you
Posts: 8.2K, Visits: 62.6K
I think you solved it yourself. Set the forward offset to zero as you were doing, and then check the Active box.
mtakerkart
mtakerkart
Thank you Rampa but I tried it and didn't fix it.
I reupload the creature in Iclone format :
https://www.dropbox.com/s/b70gfars45vg9ib/Blissp.7z?dl=0
tripfreak
tripfreak
Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)
Posts: 2.0K, Visits: 2.8K
I'm afraid there is not much you can do, because in 3DX the problem already starts from the beginning:
https://forum.reallusion.com/uploads/images/17eebda9-e629-42f2-a442-3be1.jpg
But nonetheless, thanx for bliss!
https://forum.reallusion.com/uploads/images/48ed6c4a-5b7e-49a5-9972-9943.gif
mtakerkart
mtakerkart
Hahhaha! cool!
Sorry for the wrong file , here is the good one. Same issue
https://www.dropbox.com/s/rnlglv4rgcr63uh/VAA.7z?dl=0
Last Active: 4 days ago
Posts: 5.3K, Visits: 16.8K
It'd be nice if you also provide .3DXprofile file for the last fbx, so we do not have to guess bones all over :)
mtakerkart
mtakerkart
Oups! Sorry. Here it is :
https://www.dropbox.com/s/urz2n8ualnbqhuq/Bliss_Profil.7z?dl=0
OK, I fixed him a bit in Blender (removed double vertices which were causing problem and scaled that little calf bone). You may need to reapply texture as I think it's linked from my computer.
https://www.dropbox.com/s/sp4dya5kujfhjdc/BlisspVAA_fixed.zip?dl=0
https://forum.reallusion.com/uploads/images/3a45f0e2-1ed2-48b4-9f96-f061.jpg
But ideally the feet mesh should be joint with legs and better weight painted so that there is no jagged border in between them.
matenn30
matenn30
Posts: 471, Visits: 3.3K
Will this be put out in the market place? If you put it out, I want to appreciate it.
これは、market placeに出しますか。もし出す場合、鑑賞したいです。
The forum is an amateur.
フォーラムは素人です。
mtakerkart
mtakerkart
Wow! Thank you 4u2ges. It works perfectly. unfortunately it is too advanced for me what you explain.
I should see a tutorial because I have this kind of problem very often, I use a lot of creatures with non-human postures.
if you have a little time to show it even without audio it would be cool  :D
