Mouth Open on Daz Character from CC3 to Unity
Posted By cloud.ninja 8 Years Ago
cloud.ninja
cloud.ninja
Veteran Member (743 reputation)Veteran Member (743 reputation)Veteran Member (743 reputation)Veteran Member (743 reputation)Veteran Member (743 reputation)Veteran Member (743 reputation)Veteran Member (743 reputation)Veteran Member (743 reputation)Veteran Member (743 reputation)
Posts: 26, Visits: 296
I followed the tutorial found here: https://forum.reallusion.com/397639/Special-Notice-FAQ-for-CCUnity-AutoSetup-Script and was able to get my Daz character imported from CC3 into Unity.
My new challenge is that with applying an animation, the character has it's mouth hanging open. See attached file "MouthOpenBug"
My animation works with other imported Unity characters but not Gen 3 or 8 - it leaves the mouth open. When I go to configure the CC_Base_JawRoot to another bone - after I click Done & Apply - it reverts back to the CC_Base_JawRoot?! (see image)  When I go to Muscles & Settings, I can use the Open close slide bar under Muscle Group Preview and but when I try to close the mouth using Jaw Close under the Per-Muscle Setting - nothing happens?! (see image).
I've also tried closing the mouth using blendshapes but it won't close the mouth all the way.
I'm not able to script in Unity either. Any ideas to resolve?
with appreciation,
cn
Muscles and Settings.PNG (708 views, 160.00 KB)
Threaded View
Threaded View
Forum Post Mouth Open on Daz Character from CC3 to Unity By cloud.ninja ( 8 Years Ago )
Forum Post Hi cloud.ninja, May I know if you turned off the "Auto-Processing"... By Miranda (RL) ( 8 Years Ago )
Forum Post Thanatopsis - Thank you for your reply - I also couldn't set the jaw... By cloud.ninja ( 8 Years Ago )
Forum Post Miranda (RL) - Thank you for your reply - where is that option? By cloud.ninja ( 8 Years Ago )
Forum Post [quote][b]cloud.ninja (12/31/2018)[/b][hr]Miranda (RL) - Thank you for... By Miranda (RL) ( 7 Years Ago )
Forum Post It's a bit of a strange one this. The default in Unity is 0 and when... By Ryan Hayle ( 7 Years Ago )
Forum Post [quote][b]rjhayle (2/17/2019)[/b][hr]It's a bit of a strange one this.... By Miranda (RL) ( 7 Years Ago )
Forum Post I have the exact same issue with the default CC3 settings. My... By angelin.sirbu ( 7 Years Ago )
Forum Post [quote][b]angelin.sirbu (3/13/2019)[/b][hr]I have the exact same issue... By Miranda (RL) ( 7 Years Ago )
Forum Post I deleted my animation controller - the mouth is still open I... By cloud.ninja ( 7 Years Ago )
Forum Post [quote][b]cloud.ninja (3/18/2019)[/b][hr] I also noticed that after... By Miranda (RL) ( 7 Years Ago )
Forum Post Sent! By cloud.ninja ( 7 Years Ago )
Forum Post Hi everyone, Thanks for your help in clarifying issues. Here is a... By Miranda (RL) ( 7 Years Ago )
Forum Post Thank you for the mouth open fix through script. I am primarily... By Dan Miller ( 7 Years Ago )
Forum Post I was using cc3 and iclone/faceware when I got this open mouth issue.... By Ryan Hayle ( 7 Years Ago )
Forum Post [quote][b]Miranda (RL) (4/12/2019)[/b][hr]Hi everyone, Thanks for... By mail_35 ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (3/15/2019)[/b][hr][quote][b]angelin.sirbu... By angelin.sirbu ( 7 Years Ago )
Forum Post Is this fixed??!? Seems somewhat silly how powerful iclone and cc3 is... By deidrereaystudios ( 6 Years Ago )
Forum Post Hello, From version 3.1, CC has the ability to export mouth-open... By Miranda (RL) ( 6 Years Ago )
Forum Post I tried everything here and nothing works, The mouth close-script... By adolfobolta ( 6 Years Ago )
Forum Post Hi, I also have this problem of the mouth opens and stays open when... By garrettg11 ( 6 Years Ago )
Forum Post This issue seems to be fixable. We have the same issue with Daz... By cybermynd ( 6 Years Ago )
Forum Post I don't think reordering the hierarchy solves the problem. It is not... By refuzee ( 6 Years Ago )
Forum Post You are right, it doesn’t alter the character fbx. By cybermynd ( 6 Years Ago )
Forum Post Hi everyone, If the Export Mouth-Open Morph function doesn't work,... By Miranda (RL) ( 6 Years Ago )
Forum Post For me, this problem was "fixed" by disabling automatic processing,... By fabricadegame ( 6 Years Ago )
Forum Post Problem i see with that is now you have no jaw bone.. So how would one... By deidrereaystudios ( 6 Years Ago )
Forum Post I've had that "mouth open" problem in Unity with a variety of 3D... By thanatopsis ( 8 Years Ago )
Forum Post I have no idea if this is relevant. I run into this issue all the time... By cybermynd ( 7 Years Ago )
Forum Post Embedding the Current Pose (with character in T-Pose) now prevents... By Scyra ( 7 Years Ago )
Forum Post So i ran into this issue as well, and right this moment i found the... By davidguldberg ( 6 Years Ago )
Forum Post Hi David, May we know if the mouth open result is expected as the how... By Miranda (RL) ( 6 Years Ago )
