Mouth Open on Daz Character from CC3 to Unity
Posted By cloud.ninja 8 Years Ago
3
4
neko-amatsukami
neko-amatsukami
New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)New Member (14 reputation)
Posts: 2, Visits: 20
@iuliiii You can simply creat a new animation, and animator for this...
Place your animation in your animator, and the animator on any part of your character... ( pref on the head) and open the animation windows, so you can see every bones on your character, and play with.
Anyway. if you want a little thing not really complicated, use this script.
Name it " close_mouth.cs" and place it on your characters.
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
public class close_mouth : MonoBehaviour
    private Animator animator;
    private Vector3 eulerzangle;
    // Start is called before the first frame update
    void Start()
         animator = GetComponent<Animator>();
        eulerzangle = animator.GetBoneTransform(HumanBodyBones.Jaw).transform.localEulerAngles;
        //euler = Quaternion.Euler(eulerzangle);
        Debug.Log(eulerzangle);
    // Update is called once per frame
    void LateUpdate()
        animator.GetBoneTransform(HumanBodyBones.Jaw).localRotation = Quaternion.Euler(eulerzangle);
Sorry my english is not really good.
For more idea on the animator example, Take the free " Unity-chan " model package, and look how they make her blink
praxis_labs
praxis_labs
Senior Member (310 reputation)Senior Member (310 reputation)Senior Member (310 reputation)Senior Member (310 reputation)Senior Member (310 reputation)Senior Member (310 reputation)Senior Member (310 reputation)Senior Member (310 reputation)Senior Member (310 reputation)
Posts: 15, Visits: 389
neko-amatsukami   can you share a bit, on how were you able to access the bones and key frame them in Unity. I was not able to do that with my character's bones. Thanks for your solution
TheBigEd
TheBigEd
New Member (92 reputation)New Member (92 reputation)New Member (92 reputation)New Member (92 reputation)New Member (92 reputation)New Member (92 reputation)New Member (92 reputation)New Member (92 reputation)New Member (92 reputation)
Posts: 3, Visits: 116
https://forum.reallusion.com/uploads/images/f4224ffb-4931-4a56-a721-cd7c.png
I know this is late to the party, but hopefully it will be helpful. I was able to fix the problem by selecting the avatar in the Project window, going to "Rig" then "Configure..."  In the "Mapping" UI there, click on "Head", then setting "Jaw" to "None"
neko-amatsukami
neko-amatsukami
I just make a new animation clip on the head bone (you can select the lower_jaw bone) with just 1sec of timeline, and I set the rotation of x to -0.001 at start and end of the animation
put it in an animator controller, put it on you head bone, remeber to select your character avatar, and voila.
https://forum.reallusion.com/uploads/images/8b74be65-d8f2-4d9f-ab6f-d5c0.jpg
Anyway, if you know what you do, you can put in this one animation to make your character blinking and put it on you blendshape mesh too
cognos
cognos
New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)
Posts: 5, Visits: 131
Just remove the jaw bone assignment in the head section of the avatar configuration.
You don't need this assignment, because usually the mouth is directly controlled by other subsystems, e.g. systems for lipsync, emotions, etc., to which the bones are directly assigned.
These subsystems address the bones independently of the AnimatorController via script. To avoid oddities, these bones should not be addressed in the Animator at all. In my opinion, this also applies to fingers or toes, as these are also addressed by any subsystems that may be used, such as HandPoser, FingerIK, etc.
grps.inc
grps.inc
New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)
Posts: 2, Visits: 66
This happens and is confirmed in unity 2019 as well. Still don’t have a solution🙄 character imports but after hitting play the mouth is open
thevandal421
thevandal421
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Last Active: 6 Years Ago
Posts: 1, Visits: 11
@Cybermynd Thank you for that video. I did it right after importing before doing anything else and it worked like a charm.
deidrereaystudios
deidrereaystudios
Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)
Posts: 43, Visits: 346
Problem i see with that is now you have no jaw bone.. So how would one ever get animations to work correctly without the jaw bone..??
fabricadegame
fabricadegame
New Member (9 reputation)New Member (9 reputation)New Member (9 reputation)New Member (9 reputation)New Member (9 reputation)New Member (9 reputation)New Member (9 reputation)New Member (9 reputation)New Member (9 reputation)
Posts: 1, Visits: 25
For me, this problem was "fixed" by disabling automatic processing, keeping the window open for this, and only by adding none to the mandible.
mail_35
mail_35
Junior Member (132 reputation)Junior Member (132 reputation)Junior Member (132 reputation)Junior Member (132 reputation)Junior Member (132 reputation)Junior Member (132 reputation)Junior Member (132 reputation)Junior Member (132 reputation)Junior Member (132 reputation)
Posts: 6, Visits: 61
Miranda (RL) (4/12/2019)
Hi everyone,
Thanks for your help in clarifying issues. Here is a temp solution for you now.
We found that some users who use motions without jaw bone value like Mixamo motions, character mouth will open like what you described.
There are two options we can think of at the moment.
  • If you don't need to control the mouth anymore --> delete the jaw bone (refer to this video)
  • If you will need to control the mouth --> manually change the jaw bone transform when playing those kind of motions
To make facial animation work properly, deleting jaw bone may not be a good option. Therefore, we wrote a "close_mouth" script, which you can download on the bottom of this post. This script rotates the jaw bone to make the result quite better when the animation was mapped differently.
Please put the script under the script folder,
https://forum.reallusion.com/uploads/images/388ae5ec-712a-4ea3-9645-c719.png
Check the box to close mouth.
If you want to animating mouth, you can deactivate the "close_mouth"script to back to the original status.
https://forum.reallusion.com/uploads/images/6deb4199-ee1c-4056-9028-78bd.png
Thank you, the script works.
3
4
