Mouth Open on Daz Character from CC3 to Unity
https://forum.reallusion.com/Topic398039.aspx
Print Topic | Close Window
By cloud.ninja - 8 Years Ago
I followed the tutorial found here: https://forum.reallusion.com/397639/Special-Notice-FAQ-for-CCUnity-AutoSetup-Script and was able to get my Daz character imported from CC3 into Unity.
My new challenge is that with applying an animation, the character has it's mouth hanging open. See attached file "MouthOpenBug"
My animation works with other imported Unity characters but not Gen 3 or 8 - it leaves the mouth open. When I go to configure the CC_Base_JawRoot to another bone - after I click Done & Apply - it reverts back to the CC_Base_JawRoot?! (see image)  When I go to Muscles & Settings, I can use the Open close slide bar under Muscle Group Preview and but when I try to close the mouth using Jaw Close under the Per-Muscle Setting - nothing happens?! (see image).
I've also tried closing the mouth using blendshapes but it won't close the mouth all the way.
I'm not able to script in Unity either. Any ideas to resolve?
with appreciation,
cn
By Miranda (RL) - 8 Years Ago
Hi cloud.ninja,
May I know if you turned off the "Auto-Processing" before adjusting the bone?
By thanatopsis - 8 Years Ago
I've had that "mouth open" problem in Unity with a variety of 3D figured (DAZ, Mixamo, Reallusion) and different character rigs (Unity, Invector, Ootii 3rd-person controllers). I used to be able to fix it by editing the face bones in Unity and selecting "none" for the jaw bone. That stopped working recently for some reason, maybe in Unity 2018.2 or 2018.3. I finally got sick of it and edited all my animation files. I looked at the animations in Unity from the drop-down menu WIndow > Animation > Animation and "Animator.Jaw Close" = 0 on all my offending animations. I have to change the start and end points to equal 1. The only problem is most animations are read-only, so I have to find the correct animation (easier on a new project as there aren't 25 Idle and Run animations), select it, and copy it with control-D (command-D on Mac) then rename it to something like Jaw-Idle or Jaw-Run. Then I make Animator.Jaw Close = 1 and then drag that into the Animator motion parameters to replace the old one. On the plus side, I added an "out of breath" idle pose after a sprint with the mouth opening and closing.
I had to do that for a few dozen animations, but it works for now for my simple running/jumping game. I don't know if there is an easy way to use Layers or something to make one closed jaw state and make it overlay all the other animations. If anybody has any better ideas, let me know.
Thanatopsis - Thank you for your reply - I also couldn't set the jaw bone to "none". I will try your workflow - much appreciated.
Miranda (RL) - Thank you for your reply - where is that option?
By Miranda (RL) - 7 Years Ago
cloud.ninja (12/31/2018)
https://forum.reallusion.com/uploads/images/ede62715-536b-4a01-91a7-2a73.png
By Ryan Hayle - 7 Years Ago
It's a bit of a strange one this. The default in Unity is 0 and when you look at the jaw this equals to a half open mouth. So you have to edit your read-only animations and set the Animator.Jaw Close = 1, like previously stated by thanatopsis.
I tried this and it made no difference. I noticed that when you untick the checkbox, close the window and open the window again the checkbox is set to true again.
Is this a bug?
rjhayle (2/17/2019)
Is this a bug?
This is a bug as you described.
We have fixed this issue, and it's under verification now.
Before the updated version release, please keep the window open when do any adjustment.
We also noticed that the mouth will be open when the character stays still, and will be close right when there is animation.
There is no further thing the auto-setup script can do at the moment. If there is more information, we will let you know.
By angelin.sirbu - 7 Years Ago
I have the exact same issue with the default CC3 settings. My character is the default male exported.
Is there any ETA on the fix?
Also, I cannot find the face blendshapes in the rigidbody.
angelin.sirbu (3/13/2019)
We'd like to clarify if this is the case you encountered.
https://forum.reallusion.com/uploads/images/56b60183-f0a6-4288-a5dc-9731.png
There is no motion file exported along with FBX file, which means there is no animation in the Animation Controller. When clicking play, we will see this result.
If this is the case you encounter, you can manually delete the Animation Controller, or add animation.
he question of blendshape location has been answered by a forum user, please visit your original post for details.
https://forum.reallusion.com/407209/Export-blend-shapes-for-faces-in-Unity
By cloud.ninja - 7 Years Ago
I deleted my animation controller - the mouth is still open
I unchecked "Auto-Processing" AND left the "Auto-Processing" window open while making changes to the settings - the mouth is still open.
I played an animation - the mouth is still open.
I also noticed that after making changes in the muscles and settings, clicking "apply", then "done" - when I re-open the muscles and settings - the changes are *not* applied?
Any additional help is greatly appreciated.
My configuration is:
- exporting from DAZ using FBX 2011
- I did bake the head morphs instead of "heads." settings on export from DAZ
- used CC3 Pipeline and transformation feature.
- imported the CC_Character_Auto_Settings_Unity_2018.3_PBR_Beta_1.2 script into Unity
- imported my CC3/DAZ character into the CC_Assets folder
- Using Unity 2018.3.8f1 official release on Windows 10
thank you,
.cn
cloud.ninja (3/18/2019)
It seems to be wrong. I just sent you a private message, please record your operation steps and send it to us, thank you!
Miranda (RL) (3/15/2019)
It’s not the same situation. I already have an animation controller with different states: idle, attacks, etc. Doesn’t matter which animation is played, all my characters have their mouthes open.
Sent!
Hi everyone,
Thanks for your help in clarifying issues. Here is a temp solution for you now.
We found that some users who use motions without jaw bone value like Mixamo motions, character mouth will open like what you described.
There are two options we can think of at the moment.
  • If you don't need to control the mouth anymore --> delete the jaw bone (refer to this video)
  • If you will need to control the mouth --> manually change the jaw bone transform when playing those kind of motions
To make facial animation work properly, deleting jaw bone may not be a good option. Therefore, we wrote a "close_mouth" script, which you can download on the bottom of this post. This script rotates the jaw bone to make the result quite better when the animation was mapped differently.
Please put the script under the script folder,
https://forum.reallusion.com/uploads/images/388ae5ec-712a-4ea3-9645-c719.png
Check the box to close mouth.
If you want to animating mouth, you can deactivate the "close_mouth"script to back to the original status.
https://forum.reallusion.com/uploads/images/6deb4199-ee1c-4056-9028-78bd.png
By Dan Miller - 7 Years Ago
Thank you for the mouth open fix through script. I am primarily working with Cinemachine in Unity and I use the Timeline preview most of the time rather than hitting the play button because it is a lot faster. Is it possible to modify the script to also close the mouth when hitting 'play the timeline'? I'm trying to make a movie with this workflow and always seeing the mouth open on playback is distracting but the other problem is I will be doing a lot of facial animation. The facial animation will function in the Timeline preview, without hitting the main Play button, but my preview will not be correct if the mouth is hanging open. Thanks.
I was using cc3 and iclone/faceware when I got this open mouth issue. Would it not be better to have a script that could copy and fix the animations in Unity on a push of a button? It sounds like your script only forces the mouth closed, which doesn’t sound very helpful.
By cybermynd - 7 Years Ago
I have no idea if this is relevant. I run into this issue all the time when importing Daz characters to Unity and I always fix it by simply dragging the lower jaw hierarchy into the upper jaw. After that the mouth is closed during animation and it still responds properly to blendshape application such as expressions and visemes. This is all in service of creating content for a VR app called Flipside and I've done literally hundreds of characters this way.
I apologize if this is not relevant to the Daz / CC3 / Unity workflow but I thought I would mention it.
Cheers.
By Scyra - 7 Years Ago
Embedding the Current Pose (with character in T-Pose) now prevents this problem from occuring initially. Switching Animator Controllers without copying over the pose will bring the problem back.
I tried out your method (CC_Base_JawRoot being the lower jaw hierarchy) and it appeared to work just as you described. Maybe it will come in handy sometime. Thanks for sharing.
By deidrereaystudios - 6 Years Ago
Is this fixed??!? Seems somewhat silly how powerful iclone and cc3 is to still have this issue and no quick fix or update. Please let me know if anyone has found a good solution or if there is a finalized fix. Thank YOU!!
By Miranda (RL) - 6 Years Ago
Hello,
From version 3.1, CC has the ability to export mouth-open morph.
Please find details here >> https://forum.reallusion.com/FindPost420530.aspx
deidrereaystudios (1/6/2020)
By adolfobolta - 6 Years Ago
I tried everything here and nothing works, The mouth close-script doesnt work, the mouth morph when exporting and neither the method (CC_Base_JawRoot being the lower jaw hierarchy. Mouth always open, No lip-sync whatsoever
By garrettg11 - 6 Years Ago
Hi, I also have this problem of the mouth opens and stays open when animating. It happens regardless of what kind of figure i export from CC3 to unity. And I have tried with and without ticking the mouth open morph field on the fbx export dialog. Which I am not sure I understand what that is supposed to do.
The figure was importing with a Mouth Open blendshape already, which opens the mouth if you dial the slider. After export with the mouth box ticked I end up with a new additional blendshape of 'Merged_Open_Mouth', which, yep, opens the mouth. But I need it to be closed... At runtime I can assign a negative value to the blendshape and dial in the mouth closed. Is that what we're supposed to do? So for ex the character I'm testing with, if I run my scene, which runs the characters animation controller idle animation, and in the IDE I dial in -40 for the mouth open blendshape to get it kind of where it should be. Then stop the scene and set the dial to -40. So that makes it look fugly in the ide/preview scene screen. But then running the scene once the animation kicks in the mouth sag is compensated.
And happens with any of the mechanim animation controllers and animations I have tried it with so far (limited though). Haven't gotten to the point of adding any facial animations into unity yet, still learning iclone on one side, and first things first on unity side been stuck in trying to get character textures to work correctly but noticed the mouth thing along the way.
I'm a noob to character animation and these work flows, so possibly there is some step I've not yet discovered. Is this the right way to fix this? Feels more like a workaround. Hopefully those with more experience can give us the answers or patch.
I'm also having a heck of a time getting textures to work out in unity. Maybe I am running into some bugs versus learning curve. Using unity 2019.1.14f1, (hdrp 5.16.1).
By cybermynd - 6 Years Ago
This issue seems to be fixable. We have the same issue with Daz characters being imported into Unity. This solution may be specific to Unity but it definitely does work. This video references Flipside which is a VR game but you should be able to leave that out and the character should behave exactly the same. If you only want the mouth fix go to 1:35.
https://youtu.be/cd6hVahP2ks
Hope this helps.
By refuzee - 6 Years Ago
I don't think reordering the hierarchy solves the problem. It is not really applicable to the Unity Avatar (may work with an instance in the scene but not edit the character as such).
The script provided uses LateUpdate() which overwrites all previous animations and is also not sutable for addressing the jaw as animation target. This is a hotfix for those who don't need jaw animation but not a fix for the problem. The problem is that most likely the jaw is not animated within a recording and the default position is open.
Summing up, the previous proposals don't fix the problem, at least for me. Using Mouth (+Jaw) animations via blendshapes does only work for the mouth and not for the jaw if any of the previous solutions is applied. At least for me.
You are right, it doesn’t alter the character fbx.
Hi everyone,
If the Export Mouth-Open Morph function doesn't work, may you send us the character file via Feedback Tracker?
To fix the mouth open issue, this workaround "might" satisfy your needs, please check it.
https://forum.reallusion.com/FindPost442628.aspx
Thanks!
By davidguldberg - 6 Years Ago
So i ran into this issue as well, and right this moment i found the solution. At least for this one character im working with (which is a daz 8 gen character)
Oh and im only having this open mouth issue when i convert my character to humanoid rig.
Select your character in the project folder where ever you got it stored.
Click the 'Rig' tab
After converting to Humanoid, click the 'Configure' button.
In the window with the green prototype body, click 'Head'
In my case under Jaw, i had the transform 'lowerJaw' as selected. But that transform position is not where the jaw is.
So instead i slotted in 'Chin' wich in my scene view i could see and click as the place where the jaw is.
I have attached a screenshot.
Hope it helps someone out there.https://forum.reallusion.com/uploads/images/db8922f9-38c8-4dd3-b556-4fee.png
Hi David,
May we know if the mouth open result is expected as the how it supposed to be after selecting Chin?
davidguldberg (4/28/2020)
Click the 'Rig' tab
By mail_35 - 6 Years Ago
Miranda (RL) (4/12/2019)
Hi everyone,
Thank you, the script works.
By fabricadegame - 6 Years Ago
For me, this problem was "fixed" by disabling automatic processing, keeping the window open for this, and only by adding none to the mandible.
Problem i see with that is now you have no jaw bone.. So how would one ever get animations to work correctly without the jaw bone..??
