Daz Genesis8_X_iCloneFaceKey.duf and Genesis3_X_iCloneFaceKey.duf issues
Posted By fsilva 7 Years Ago
Daz Genesis8_X_iCloneFaceKey.duf and Genesis3_X_iCloneFaceKey.duf...
fsilva
fsilva
Posts: 78, Visits: 718
The reason I'm inquiring if the output files from Daz, Genesis3 Male & Female and Genesis8 Male and Female are working appropriately. I followed very closely Kai's tutorial after Reallusion updated the duf files, but in Kai's video, I could see much more facial movements than my iAvatar files. I included an iAvatar as a test model so you can take it out for a spin. All comments and feeback are gratefully accepted. Thanks!
https://drive.google.com/open?id=1rULXCdfhyF0n2ML5uwM67Z8tpVgUZHpe
kungphu
kungphu
Last Active: 4 days ago
Posts: 997, Visits: 7.1K
This is just a “dumb” suggestion, but have you tweaked the settings in iclone for strength in the animation tab? I’m not sure what %Kai was using for facial expression in his video. He may have dialed it in a bit higher. I’ve genrally been pleased with the dud files but found for cartoon style expressions you really had to dial those in individually. Just a thought!
My "NEWEST" Latest:)  Movie Made With Amaaaazing iClone
fsilva
fsilva
To further substantiate my claims, I went into face puppet. This was the message iClone gave me...
"Due to insufficient expression data of the target character, sliders of the Face Key and Face Puppet panels may be partially disabled. Use 3DXchange 7 to fill out the expression data."
fsilva
fsilva
Here's the event...
kungphu
kungphu
Hmmm... I’ve knly seen that error when I’ve used an older character prior to the facial animation update. The new dud files have a lot more expressions. That error pops up when I have a character with not enough expressions mapped to it. Are you certain you are using the latest DUF file? Also are you making sure Daz adds all of the additional frames for the DUF file? There should be something like 80, I’ll have to double check. But it’s a considerably larger amount than what we had in the old iclone 6 DUF files. This isn’t a great solution, but if you have a deadline you can map out the missing expressions by hand using a combination of morphs. It’s a PITA, but it’ll work.
damianabel
damianabel
New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)
Posts: 1, Visits: 45
The same thing is happening to me. Any solution?
Posts: 23.1K, Visits: 36.6K
Do make sure you have correctly copied the appropriate  "Reallusion" folder to Daz Studio.
So for example copy the Reallusion folder from iClone_Daz_Genesis_Extension_v4_IC7\DAZ Genesis Extension\Daz Genesis to iClone\Genesis3_Female to the location below (default install).
C:\Users\Public\Documents\My DAZ 3D Library\data\DAZ 3D\Genesis 3\Female\Morphs
Then make sure you restart Daz Studio for the changes to take effect. Now once you apply the Genesis3_Female_iCloneFaceKey.duf file to your character it should be correctly assigned. Then do the same for the male and Genesis 8 characters. Instructions are also supplied in the iClone_Daz_Genesis_Extension_v4_IC7.zip file.
fsilva
fsilva
Peter, as así posted before, Not every Daz user has the same configuration. For example, the default configuration so that the Reallusion folder can work in Daz automatically determines that EVERY Daz user has Daz Studio installed in the C:\ drive as a default. On my system, I have a small SSD drive for my Windows boot drive. Every other application is in either my D, F J or L drives. The only time I got the ver. 4 Duf to work was when I installed Daz on my laptop, which, of course, defaults only to a C:\ drive. In fact, I even installed Daz Studio 4.10 on the laptop and the Duf didn't work. Only when Daz Studio 4.9 was installed on the laptop was when I was able to get the 58 facial expressions. Now, I ask you, what version of Daz Studio are your staff using. It's difficult to get the same results if we don't know what the ver. 4 .Duf was developed on.
fsilva
fsilva
fsilva (8/3/2018)
Last Active: 10 days ago
Posts: 8.2K, Visits: 62.5K
Also make sure you are not running DAZ as administrator. That seems to mess it up.
