Change Character Cloths in Unity
Posted By carlosmelo1991 7 Years Ago
carlosmelo1991
carlosmelo1991
Veteran Member (788 reputation)Veteran Member (788 reputation)Veteran Member (788 reputation)Veteran Member (788 reputation)Veteran Member (788 reputation)Veteran Member (788 reputation)Veteran Member (788 reputation)Veteran Member (788 reputation)Veteran Member (788 reputation)
Last Active: 5 Months Ago
Posts: 2, Visits: 54
Hi there,
I am new using Iclone and Character Creator, I bought the pipeline licenses. I would like to know if it is possible to export characters with multiple clothing and accessories so that they can be swape in Unity at runtime.  If so, Does anyone know
 of a tutorial or instructions on how to do it?
Thank you so much!
Threaded View
Threaded View
Forum Post Change Character Cloths in Unity By carlosmelo1991 ( 7 Years Ago )
Forum Post the easy way would to export the character out just make sure when you... By jaxensstore ( 7 Years Ago )
Forum Post bump. Has anyone figured this out? Is C3 even valid for this purpose?... By drewdough ( 6 Years Ago )
Forum Post See if this sends you in the right direction.... By Rampa ( 6 Years Ago )
Forum Post It is fundamentally a lot of work. You may create variants of the... By lollosone ( 6 Years Ago )
Forum Post I'm running into a similiar issue. I've been able to dres a character... By dpage ( 6 Years Ago )
Forum Post at Rampa https://www.youtube.com/watch?v=0ZWH7X3lvMM this helps... By Jbowdoin ( 4 Years Ago )
Forum Post another way to ward it is how can I give them a unified avatar /... By Jbowdoin ( 4 Years Ago )
Forum Post Hi Folks, First off, big shout out to Rampa - always with great... By felgryn ( 3 Years Ago )
Forum Post Hi Folks, Found an answer.... I started down a path based upon a... By felgryn ( 3 Years Ago )
Forum Post yes that video is what you want , I have been doing this for a... By Jbowdoin ( 3 Years Ago )
Forum Post There are 20 clothing layers. If you look in the bottom-left corner of... By Rampa ( 6 Years Ago )
Forum Post I've not had much success with either approach using the Beta 2... By glugsolro ( 6 Years Ago )
Forum Post Hi Rampa, Thanks for the tutorials! I see you are always there to... By Jfrog ( 6 Years Ago )
Forum Post [quote][b]Jfrog (7/23/2019)[/b][hr]Hi Rampa, Thanks for the... By Rampa ( 6 Years Ago )
Forum Post Thanks for the quick reply Rampa. :) The problem is that I would... By Jfrog ( 6 Years Ago )
