dennisallums
dennisallums
Visits: 40
Dozens of I-clone users having the same problem with expression editor. It works for head and eyes but not anything else. We've even asked Kai on the thread but he says go here. LoL. here is a link to all the people with same problem. https://www.youtube.com/watch?v=6umSgDdSnw0&t=397sRead the replies.
Visits: 62.6K
dennisallums (2/7/2018)
Dozens of I-clone users having the same problem with expression editor. It works for head and eyes but not anything else. We've even asked Kai on the thread but he says go here. LoL. here is a link to all the people with same problem. https://www.youtube.com/watch?v=6umSgDdSnw0&t=397sRead the replies. The Genesis Extension was updated not to long ago to make DAZ Genesis characters have the proper morph setup to work with the updated facial animation and Faceware plugin. So if you have iClone7 and 3DX7, make sure you have downloaded the new extension. It is in the download link for 3DX7 on your registration page. Genesis 1 - 8 are supported.
EddieChristian
EddieChristian
Visits: 544
So I am going to Mention a few errors. Some are in different apps. But I assume they are using Pipeline to export. 1 First I had a student who attempted to set up a Non-Standard Character using an FBX from the Unity Asset store. When he couldn't do it, I checked it out with the same file. When you get to the part where you test the motions, It ripped the mesh to shreds. Now this is a properly weighted mesh that has been sold on the Unity store for a year. 2 FBX Export from Character Creator and iClone don't properly export all maps. in some case it only outputs a few maps and in some cases it exports No Maps. 3 In Character Creator some PBR iAvatar exports have come back in as Standard Materials. (Standard Materials Should be Removed Entirely at this Point) Lastly I am going to state that Refusal to Allow a Quad Mesh Pipeline is a Flaw and a Bug. It means your tools can NOT be properly used in either a Video or Film Pipeline.
Visits: 62.6K
@Grfxman
Could you post a pic or video of the "ripping to shreds". It is most likely that the hip bone, or a torso bone, is incorrectly mapped.
The proper hip bone is the one right after the bone coming up from the floor. It may not be what looks like the hips.
TopOneTone
TopOneTone
Visits: 3.2K
I have also had some problems with 3dxchange7. I purchased a Daz model of a dog and exported it out of Daz. Imported it into 3dxchange 7 ok, added the animation to perform and then converted to a non human. My first issue was that when I tried to export into iclone I kept getting the following error message "Export Failed. Please check your access right to the folder and the disk space." I tried changing the folder locations for the character and the motion, but it made no difference. I went through the whole process again using 3dxchange 6 and it worked first time. My second issue came when I realised I needed to increase the size of the dog. There appeared no way to do this in iclone or 3dxchange, so I went back to Daz. I simply increased the scale and everything looked fine in Daz, but when I brought it into 3dxchange 7 the front half of the dog was still the original size, while the back half was distorted with a huge bulging stomach. I tried the same thing with other Daz dogs and got exactly the same problem. Any thoughts on where I'm going wrong? I have to say I am really disappointed that there is no way to adjust the character's size or the materials in 3dxchange. I can see there are options within the menu, but I can't access them.
Visits: 62.6K
TopOneTone (2/23/2018) I have also had some problems with 3dxchange7. I purchased a Daz model of a dog and exported it out of Daz. Imported it into 3dxchange 7 ok, added the animation to perform and then converted to a non human. My first issue was that when I tried to export into iclone I kept getting the following error message "Export Failed. Please check your access right to the folder and the disk space." I tried changing the folder locations for the character and the motion, but it made no difference. I went through the whole process again using 3dxchange 6 and it worked first time. My second issue came when I realised I needed to increase the size of the dog. There appeared no way to do this in iclone or 3dxchange, so I went back to Daz. I simply increased the scale and everything looked fine in Daz, but when I brought it into 3dxchange 7 the front half of the dog was still the original size, while the back half was distorted with a huge bulging stomach. I tried the same thing with other Daz dogs and got exactly the same problem. Any thoughts on where I'm going wrong? I have to say I am really disappointed that there is no way to adjust the character's size or the materials in 3dxchange. I can see there are options within the menu, but I can't access them.
For the export issue, check that you do not have any dots, or other non-alphanumerics in the names of the animations. I think the underscore "_" is the only non-alphnumeric you can use. When you import it into 3DX, you can scale it before you convert it to an avatar. I would actually suggest not converting it, but leave it a prop. The motions will be embedded in the Perform menu for it, and iClone lets you edit the prop animation layer if you want to. A prop can be freely scaled, so you actually wouldn't even need to scale it in 3DX. You can add textures to the materials in the material section of 3DX, but I recommend doing the textures in iClone's material section. It's a bit more WYSIWYG.
Colonel_Klink
Colonel_Klink
Posts: 1.1K,
Visits: 7.7K
OBJ export from 3DXchange 7.2 Pro is not keeping smoothing done in Xchange Recently I purchased 3DX 7 Pro so I could export my prop files from iClone 7 as 3DX 6.5 will not open iClone 7 files. However I find that I am not getting the same results from 3DX 7 as I do from 3DX 6 as you can see from the 2 pics below when I import the model into Substance Painter   I have checked the settings are the same for both exports. The workaround atm is to export from iClone 7 to 3DXchange 7 to OBJ, then import the obj into 3DXchange 6, do the smoothing, then export as OBJ... it works but it is NOT why I purchased 3DXchange 7.
* * * * * * * * * * * * * * * * * * See all my content in one place
 Facebook Page: CWK3D Game and Film Content Cancer Survivor - Retired Teacher - Geriatric Icloner still learning Hardware: ZX80; Operating System- ZX80 Basic; CPU - ZX80 @ 3.25 MHz; Memory - 1KB; Hard Drive - N/A; Storage - Cassette; Monitor: Any old CRT TV
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
FYI: 3DXchange v7.2 Replace Mesh Is Broken
-- guy rabiller | GOETZIWOOD STUDIOS "N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
Rogue Anime
Rogue Anime
Visits: 3.4K
Colonel_Klink (3/8/2018) The workaround atm is to export from iClone 7 to 3DXchange 7 to OBJ, then import the obj into 3DXchange 6, do the smoothing, then export as OBJ... it works but it is NOT why I purchased 3DXchange 7.Colonel - I have had to go BACK to 3DX6.5 to do MANY things since I purchased 3DX7, and that's really not the most troubling thing about 3DX7 - What is more troubling about this is that by all indications there will be NO fixes for 3DX7. If there are to be ANY fixes addressed to this, I heard none here or missed something...? :angry: ~V~
Val RogueAnanda
TopOneTone
TopOneTone
Visits: 3.2K
Still having constant problems with 3dxchange 7.2 crashing when the same models work perfectly well in 3dxchange 6. I notice that despite being the originators of this thread, there has been no further comment from RL, even after 3 pages of people identifying a variety of problems. Given the exorbitant price RL charge for this product you would have thought RL would be on top of these issues or at least provide regular progress updates to indicate they are working to address these problems....but not a word! MY STRONG ADVICE TO ANYONE CONSIDERING BUYING 3DXCHANGE 7 IS DON'T! Until the current issues are fixed this product is a total waste of money.
