Last Active: 18 minutes ago
Posts: 18.7K,
Visits: 28.9K
Dear 3DXchange Users,We have another new 3DXchange 7 update and need your continued assistance to help us track down any remaining bugs, glitches or other annoying issues. 3DXchange 7.2 comes with a number of important fixes and enhancements.Important: If you do find any bugs, issues or glitches in the 7.2 update, please can you report them first in the Feedback Tracker. Then feel free to discuss the issues in this thread. However do make use of the Feedback Tracker first to log the issue. As always it will help us greatly if we can keep all outstanding issue discussion in the one place (this thread). This will help the development team keep track of any problems.Please do try to provide your full system specifications and a detailed description of the problem when reporting issues. If you can provide steps so we can try and reproduce the problem this will be even better.Many Thanks.
rollasoc
rollasoc
Visits: 2.8K
Logged through support. But I can't get 3d exchange to run at all. Just crashes on startup. I will play with my driver settings tomorrow, to see if I can fix it.
Home built PC:- i9 9900K 32GB RAM, Zotac 1080TI mini. Band Music:- https://thehairthieves.bandcamp.com/ Solo Instrumentals:- https://sineglidermusic.bandcamp.com/
rollasoc
rollasoc
Visits: 2.8K
Played with driver settings, still no luck. 3d exchange just crashes on startup.
I have uninstalled and reinstalled 3d Exchange. Tried launching from start, tried launching by clicking on a FBX file. Just crashes.
So much for my week of importing some Daz assets into iClone.
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
Have a read through this thread https://forum.reallusion.com/326325/Cant-launch-3dXchange-but-can-launch-IcloneC++ seems to have caused issues for 3dxchange perhaps this might also be what you need to reinstall Hope it helps
Duchess Designs Store
rollasoc
rollasoc
Visits: 2.8K
Thanks for that. I did do a repair on the 2013 Runtime earlier, but that didn't fix the issue. Here is what C++ redistributables, I have installed.  3D Exchange has been working up until I installed 7.2 last weekend. I'm going to uninstall and install an old version. See if that works, so I can at least do some work, then try upgrading it again.
4 Years Ago by
rollasoc
rollasoc
rollasoc
Visits: 2.8K
Uninstalled 2013 C++ redistributable. Uninstalled 3dexchange
Re-installed 2013 C++ redistributable rebooted installed older 3d exchange pro 7.0 That failed to load (never had any issues with it before I bought pipeline) Uninstalled pro rebooted re-installed 3dexchange pipeline
Still crashes on startup.
Starting to think, 3dexchange isn't liking something in the latest Radeon drivers? (on a laptop, so no I can't swap it for another card)
Posts: 7.6K,
Visits: 46.3K
Are you running dual graphics on your laptop? If you have both on-chip graphics, and discreet graphics, make sure 3DX is running on the discreet.
4 Years Ago by
rollasoc
rollasoc
Visits: 2.8K
I do have dual graphics. 3dexchange is set up for performance on my graphics card. So it shouldn't be using the onboard one. I will investigate.
EddieChristian
EddieChristian
Visits: 464
Convert to Non Standard is Totally Broken. It was brought to my attention by a student. And After testing I can say that it just ripps the mesh to shreds when you run any of the test animations.
WillFl
WillFl
Visits: 161
3DXchange is failing to honor the TPose for a custom character. Seems to push both feet together when you export as FBX.
