OFFICIAL iClone 7.2 Issues Thread
Posted By Peter (RL) 9 Years Ago
Rated 1 star based on 1 vote.
5
6
7
8
9
10
11
TonyDPrime
TonyDPrime
Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)
Posts: 3.4K, Visits: 12.4K
Rogue Anime (1/8/2018)
TonyDPrime (1/8/2018)
Here is another issue: When adding Post Effect (Visual > Post Effect), such as an LUT, the resulting key(s) created in timeline can not be deleted from timeline. Right Click is grayed-out.
Friends -
I have not run into this YET... Although I have noticed a few iClone 7 bugs, this isn't one I have had a problem with. I was editing HDR effects on my timeline this  morning. Select & delete/moving HDR animation sliders are no problem here... Hmmm not certain what the problem could be there.   ~V~
To your thought, it indeed seems the HDR slider stuff (ie- IBL strength, Exposure, etc) is in fact deletable on the timeline.
But when you add an actual Post Effect it cannot be deleted.
So, yes, you can modify the HDR settings, ie - set Bloom amount on frame 100 to max, and then go and later delete that key on frame 100.
But if you add a Post Effect LUT, and then say change the amount of this LUT on frame 100, you cannot delete that key on the timeline, it is greyed out.  You are stuck with it, unless deleted from the Post Effect list as Wires pointed out
Keys in timeline from here CAN be deleted
https://forum.reallusion.com/uploads/images/8cf27ed8-b3f8-4f89-982f-c95d.jpg
Keys in timeline from here can NOT be deleted
https://forum.reallusion.com/uploads/images/6429c2eb-9ec4-4571-bd4f-1a7c.jpg
Regards!
TonyD
TonyDPrime
TonyDPrime
wires (1/8/2018)
A note on my post above.
All of the post effects can be deleted simply by selecting them in the Effects list panel and then clicking on the "Delete" icon.
There are 2 Delete options - Delete
https://forum.reallusion.com/uploads/images/3540be97-5561-4f63-8ad8-a5a2.png
and Delete All if there are several effects in the list.
https://forum.reallusion.com/uploads/images/b56af547-6b39-4456-8b7e-d8b8.png
NICE...This is a good workaround, thanks for this!
I could imagine, as ToystoryLab pointed out, if I had multiple keyed instances it will be quite cumbersome to rely on the workaround, it optimally should be delete-able on the timeline itself.
ie- if you have several instances, you shouldn't be forced to delete all instances because you want to take away one instance.
Although, an additional workaround could then be to add an independent instance in the Post Effect list, for each time-lined instance.  That way, if you had 5 instances, and if you wanted to delete #3, you just delete the 3rd instance in the list, thus preserving the other 4.  But, this agreeably will be unnecessarily complex and problematic.
Posts: 5.7K, Visits: 26.5K
Confirmed.
No key frames set on the Post Effects track can be deleted/copied/cut or whatever using the right mouse button.
Key frames set on any other track can be deleted as expected.
yossigolan
yossigolan
New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)
Posts: 1, Visits: 122
Yet another issue:
When adding a .POPVIDEO plane that contains sound to a new empty project then:
1. the popvideo clip is working fine in iclone itself, and it is played well and you can hear the sound of the clip.
2. when trying to render the file you get a MP4 or AVI that is missing the popvideo clip sound.
Thus playing the file you can't hear the sound of the popvideo clip.
I even tried to render the audio only (WAV) but still i get a muted WAV file.
I've allready installed K-Lite package but that didn't solved it.
I have an intel i7-7700 cpu 3.6Hgz 16GB ram and nvidia 1060 with 6GB memory.
I've also tried this procedure on a different computer and have the exact same issue.
My project is based on .popvideo clips that contain sound and this issue is preventing me
from rendering my project...
Your help will be very appreciated.
Rogue Anime
Rogue Anime
Posts: 548, Visits: 3.4K
Friends -
       Val RogueAnanda
https://forum.reallusion.com/uploads/images/e82de505-c57a-40b9-8cb0-9f87.png
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Last Active: 4 days ago
Posts: 4.6K, Visits: 29.9K
Confirmed...
And NO, you can't delete it by hitting delete on the keyboard...
Only "undo" works, but that's no help if you decide not to use it after doing a lot of work.
Rockoloco666
Rockoloco666
Group: Banned Members
Last Active: 6 Years Ago
Posts: 762, Visits: 2.0K
Does it work if you hit delete on the keyboard?
TonyDPrime
TonyDPrime
https://forum.reallusion.com/uploads/images/744b7243-7759-40a4-9d43-323c.jpg
mark
mark
Posts: 4.9K, Visits: 16.7K
That's what seems to be  happening to me, it was by the third recording ...
P.S. and the avatar even jumps to another location...very weird
PROMO-BACK2
5
6
7
8
9
10
11
