Export character animation with props
Posted By eclyptik 8 Years Ago
jorgeferherrero
jorgeferherrero
Senior Member (366 reputation)Senior Member (366 reputation)Senior Member (366 reputation)Senior Member (366 reputation)Senior Member (366 reputation)Senior Member (366 reputation)Senior Member (366 reputation)Senior Member (366 reputation)Senior Member (366 reputation)
Last Active: 7 Years Ago
Posts: 21, Visits: 124
fail
eclyptik
eclyptik
Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)
Posts: 15, Visits: 62
Question : can we display the path of an animation object use key files ? like Trajectory display in 3dsmax ?
eclyptik
eclyptik
TIPS : Uncheck Dummy parent for exporting props child is better than dummy checked. i saw it's instable at this moment.
eclyptik
eclyptik
This is entire animation rendering from iclone for show you.
Maybe some ideas for improve this animation. Don't hesitate to bring your point of view
I have many sliding feets by example...
eclyptik
eclyptik
Sure Rampa. i do this method before. it works nice. i would to do other way for make better and elevate the level.
i would add ik animation for take object.
Cheers
eclyptik
eclyptik
thanks VIDI.
But if you tried to export two character in same time in FBX , it works great !
why not for props too...
they add export FBX in iclone 7.1. i think it for use it. i think we can export in first time a simple hierachy
with 2 or 3 dummy liked or attached with a dummy in zero world for have .
is it very difficult ? for me it's bug... nothing else. You don"t think.
than if its a bug.. ok i will patiented. but it not why it not works.
Posts: 8.2K, Visits: 62.6K
Another possibility would be to attach the objects to the hands. This makes them sub-props (accessories). The toggle the visibility of them in Unity (can that be done?). You would also toggle the visibility of a prop-version on the ground. Have the ones in the hands appear at the same time to ones on the ground disappear.
For an immediate fix, I would suggest exporting an Alembic file. This would capture the mesh exactly as it is in iClone. You will need to re-apply the textures in Unity, as Alembic only caries mesh data, not materials.
Have a look at this tutorial to understand how to use the Alembic. Just substitute Unity for Maya.
eclyptik (12/13/2017)
another video show the problem. Maybe somebody who have the same problem have a solution please ?
This looks like a genuine issue to me, and I will try and figure out what is going on. Thank you for pointing it out! :) This video clarifies what the issue is.
Everyone else: Lets not jump on someone because they are in a desperate situation. This could be someones livelihood!
vidi
vidi
Posts: 10.8K, Visits: 40.2K
create animamtion and export ton unity or other program
animated Character and animated prop can exported with fbx , but not whole animated scenes. To bring it together is the part of your target tool
liebe Grüße vidi
