Export character animation with props
Posted By eclyptik 8 Years Ago
eclyptik
eclyptik
Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)Senior Member (294 reputation)
Posts: 15, Visits: 62
Hi, i have many problem for export my character animation who interac with props. The props are not in the good place after export.
It is very difficult. i lost many time for find a solution. I try many way but no sucess.
Somte time i try to link a props to a dummy and reach the hand of he character to the dummy and move the dummy with key animation but the result is poor.
I used Export FBX from iclone 7 direclty.
See an example : this is just a rotation of the props for see the resul after export and the rotation in 3dsmax is not the same, I just do 90 degree in clone and in 3dsmax i do more 90 degree
the pivot is in center and the scale object is 100%. I have no idea. is it a bug of iclone with exporting FBX. same way with just a box !!!
https://forum.reallusion.com/uploads/images/d885f904-de94-4cbb-be10-05d3.jpg
https://forum.reallusion.com/uploads/images/d5127e49-bed2-4f25-8b7c-b40f.jpg
Threaded View
Threaded View
Forum Post Export character animation with props By eclyptik ( 8 Years Ago )
Forum Post A make a video for show my problem fo exporting animation in 3dsmax.... By eclyptik ( 8 Years Ago )
Forum Post ... By eclyptik ( 8 Years Ago )
Forum Post Look i put just a cube with pivot to center, i place the box to Zero... By eclyptik ( 8 Years Ago )
Forum Post Another export with very bad results Reallusion can Explain ???... By eclyptik ( 8 Years Ago )
Forum Post Since you want to keep spamming this everywhere, I'll speak up and... By Kelleytoons ( 8 Years Ago )
Forum Post oh yes i understand ! But the problem with the marketing of iclone,... By eclyptik ( 8 Years Ago )
Forum Post fail By jorgeferherrero ( 8 Years Ago )
Forum Post another video show the problem. Maybe somebody who have the same... By eclyptik ( 8 Years Ago )
Forum Post [quote][b]eclyptik (12/13/2017)[/b][hr] another video show the... By Rampa ( 8 Years Ago )
Forum Post if you want to banned me because you don't have solution. Ok Go... By eclyptik ( 8 Years Ago )
Forum Post [quote]create animamtion and export ton unity or other... By vidi ( 8 Years Ago )
Forum Post thanks VIDI. But if you tried to export two character in same time in... By eclyptik ( 8 Years Ago )
Forum Post For an immediate fix, I would suggest exporting an Alembic file. This... By Rampa ( 8 Years Ago )
Forum Post Another possibility would be to attach the objects to the hands. This... By Rampa ( 8 Years Ago )
Forum Post Sure Rampa. i do this method before. it works nice. i would to do... By eclyptik ( 8 Years Ago )
Forum Post This is entire animation rendering from iclone for show you. Maybe... By eclyptik ( 8 Years Ago )
Forum Post TIPS : Uncheck Dummy parent for exporting props child is better than... By eclyptik ( 8 Years Ago )
Forum Post Question : can we display the path of an animation object use key... By eclyptik ( 8 Years Ago )
