Visits: 62.6K
eclyptik (12/13/2017) another video show the problem. Maybe somebody who have the same problem have a solution please ?
This looks like a genuine issue to me, and I will try and figure out what is going on. Thank you for pointing it out! :) This video clarifies what the issue is. Everyone else: Lets not jump on someone because they are in a desperate situation. This could be someones livelihood!
Visits: 62.6K
For an immediate fix, I would suggest exporting an Alembic file. This would capture the mesh exactly as it is in iClone. You will need to re-apply the textures in Unity, as Alembic only caries mesh data, not materials.
Have a look at this tutorial to understand how to use the Alembic. Just substitute Unity for Maya.
Visits: 62.6K
Another possibility would be to attach the objects to the hands. This makes them sub-props (accessories). The toggle the visibility of them in Unity (can that be done?). You would also toggle the visibility of a prop-version on the ground. Have the ones in the hands appear at the same time to ones on the ground disappear.
eclyptik
eclyptik
Visits: 62
thanks VIDI. But if you tried to export two character in same time in FBX , it works great ! why not for props too...
they add export FBX in iclone 7.1. i think it for use it. i think we can export in first time a simple hierachy with 2 or 3 dummy liked or attached with a dummy in zero world for have . is it very difficult ? for me it's bug... nothing else. You don"t think. than if its a bug.. ok i will patiented. but it not why it not works.
eclyptik
eclyptik
Visits: 62
Sure Rampa. i do this method before. it works nice. i would to do other way for make better and elevate the level. i would add ik animation for take object.
Cheers
eclyptik
eclyptik
Visits: 62
This is entire animation rendering from iclone for show you. Maybe some ideas for improve this animation. Don't hesitate to bring your point of view I have many sliding feets by example...
eclyptik
eclyptik
Visits: 62
TIPS : Uncheck Dummy parent for exporting props child is better than dummy checked. i saw it's instable at this moment.
eclyptik
eclyptik
Visits: 62
Question : can we display the path of an animation object use key files ? like Trajectory display in 3dsmax ?
jorgeferherrero
jorgeferherrero
Last Active: 7 Years Ago
Visits: 124
fail
