VirtualMedia
VirtualMedia
Visits: 19.0K
How can you adjust the teeth in the Cavity Menu in CC if you adjust the teeth in iClone? Had a tongue poke through and used the facial feature adjustment in iClone and then sent character back to CC for more adjustments but the teeth won't move? I tried resetting, deleting and replacing the teeth but nothing seems to work...?
Virtual Media® / VTV® / The Virtual Entertainment Network... http://VTVLive.com
Visits: 22.1K
Hmmm, wonder if this is another of those "you need to save the character in CC format so you can edit it later" sort of things?
VirtualMedia
VirtualMedia
Visits: 19.0K
Kelleytoons (10/6/2017) Hmmm, wonder if this is another of those "you need to save the character in CC format so you can edit it later" sort of things?I usually do, but I had worked on this character for quite some time and started eliminating duplicates, I guess I got to the point of no return. One thing I've noticed / learned it seems the more back and forth for IC to CC - ZB... the more control you loose over the character. Needless to say I had to start over and learned too much tweaking is not a good idea..
