Cant adjust teeth in character creator after using facial features in iclone
Posted By VirtualMedia 3 Years Ago
Cant adjust teeth in character creator after using facial features in...
VirtualMedia
VirtualMedia
Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)
Posts: 547, Visits: 18.8K
How can you adjust the teeth in the Cavity Menu in CC if you adjust the teeth in iClone? Had a tongue poke through and used the facial feature adjustment in iClone and then sent character back to CC for more adjustments but the teeth won't move?
I tried resetting, deleting and replacing the teeth but nothing seems to work...?
VTV® and Virtual Media® Are part of The Virtual Broadcasting Network™  Stay Tooned...
http://VTVLive.com
Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)Distinguished Member (23.6K reputation)
Last Active: 25 minutes ago
Posts: 7.3K, Visits: 15.3K
Hmmm, wonder if this is another of those "you need to save the character in CC format so you can edit it later" sort of things?
VirtualMedia
VirtualMedia
Kelleytoons (10/6/2017)
I usually do, but I had worked on this character for quite some time and started eliminating duplicates, I guess I got to the point of no return. One thing I've noticed / learned it seems the more back and forth for IC to CC - ZB... the more control you loose over the character.
Needless to say I had to start over and learned too much tweaking is not a good idea..
http://VTVLive.com
3 Years Ago by VirtualMedia
