Cant adjust teeth in character creator after using facial features in iclone
https://forum.reallusion.com/Topic343943.aspx
Print Topic | Close Window
By VirtualMedia - 9 Years Ago
How can you adjust the teeth in the Cavity Menu in CC if you adjust the teeth in iClone? Had a tongue poke through and used the facial feature adjustment in iClone and then sent character back to CC for more adjustments but the teeth won't move?
I tried resetting, deleting and replacing the teeth but nothing seems to work...?
By Kelleytoons - 9 Years Ago
Hmmm, wonder if this is another of those "you need to save the character in CC format so you can edit it later" sort of things?
Kelleytoons (10/6/2017)
I usually do, but I had worked on this character for quite some time and started eliminating duplicates, I guess I got to the point of no return. One thing I've noticed / learned it seems the more back and forth for IC to CC - ZB... the more control you loose over the character.
Needless to say I had to start over and learned too much tweaking is not a good idea..
