VirtualMedia
VirtualMedia
Visits: 18.8K
How can you adjust the teeth in the Cavity Menu in CC if you adjust the teeth in iClone? Had a tongue poke through and used the facial feature adjustment in iClone and then sent character back to CC for more adjustments but the teeth won't move? I tried resetting, deleting and replacing the teeth but nothing seems to work...?
VTV® and Virtual Media® Are part of The Virtual Broadcasting Network™ Stay Tooned... http://VTVLive.com
Posts: 7.9K,
Visits: 17.3K
Hmmm, wonder if this is another of those "you need to save the character in CC format so you can edit it later" sort of things?
Alienware Aurora R7, Win 10, i7-8700k, 4.7GHz CPU, 32GB RAM, GTX Titan XP (12GB), Samsung 960 Pro 2TB M-2 SSD, TB+ Disk space Mike "ex-genius" Kelley
VirtualMedia
VirtualMedia
Visits: 18.8K
Kelleytoons (10/6/2017) Hmmm, wonder if this is another of those "you need to save the character in CC format so you can edit it later" sort of things?I usually do, but I had worked on this character for quite some time and started eliminating duplicates, I guess I got to the point of no return. One thing I've noticed / learned it seems the more back and forth for IC to CC - ZB... the more control you loose over the character. Needless to say I had to start over and learned too much tweaking is not a good idea..
4 Years Ago by
VirtualMedia
