CrazyTalk 8 slow performance on a 4 minute clip
Posted By qacer 4 Years Ago
qacer
qacer
Junior Member (244 reputation)Junior Member (244 reputation)Junior Member (244 reputation)Junior Member (244 reputation)Junior Member (244 reputation)Junior Member (244 reputation)Junior Member (244 reputation)Junior Member (244 reputation)Junior Member (244 reputation)
Posts: 9, Visits: 20
Hi all,
I have CrazyTalk 8. This weekend was the first time I've tried using it. I wanted to do a 2D actor talking head synced to a 4 minute song. I created a 2D actor from a picture. Then, I followed the lip syncing tutorial and ended up with the song as the background music and my voice-over controlling the lip syncs. I was disappointed with the performance. I could not properly modify the lip syncs because each time I hit play there was a delay with the actual animation preview. Basically, I hear the audio going, but the screen is frozen and delayed for a few seconds. It made figuring out where the vocals aligned with the actual frame difficult.
I'm not sure if there are any tips to optimize the performance, but I wanted to get a check whether my system specs are sufficient to be able to do a real time preview without any delays.
I currently have the following:
OS Name:    Microsoft Windows 10 Home
Version:   10.0.10586 Build 10586
OS Manufacturer:   Microsoft Corporation
System Manufacturer:    Dell Inc.
System Model:   XPS 8500
System Type:   x64-based PC
Processor:   Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM):   12.0 GB
Total Physical Memory:   12.0 GB
Available Physical Memory:   6.69 GB
Total Virtual Memory:   13.8 GB
Available Virtual Memory:   4.99 GB
Hyper-V - VM Monitor Mode Extensions   Yes
Hyper-V - Second Level Address Translation Extensions   Yes
Hyper-V - Virtualization Enabled in Firmware   Yes
Hyper-V - Data Execution Protection   Yes
Description:   Local Fixed Disk
Compressed:   No
File System:   NTFS
Size:   1.82 TB (1,999,316,709,376 bytes)
Free Space:   504.09 GB (541,259,653,120 bytes)
Adapter Type:   AMD Radeon Graphics Processor
Adapter Description:   AMD Radeon HD 7700 Series
Adapter RAM:   (2,147,483,648) bytes
Radeon Software Version - 16.3.2
Radeon Software Edition - Crimson
Graphics Chipset - AMD Radeon HD 7700 Series
Memory Size - 2048 MB
Memory Type - GDDR5
Core Clock - 1000 MHz
Windows Version - Windows 10 (64 bit)
System Memory - 12 GB
CPU Type - Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Are these specs sufficient?
If they are, how do I improve the performance of CrazyTalk 8, so I can replay the animation, background music, and voice-over smoothly during preview?
If these specs are not sufficient, would getting a different video card such as an Nvidia Quadro K2200 help?
Thanks!
vidi
vidi
Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)Distinguished Member (24.5K reputation)
Last Active: 10 hours ago
Posts: 10.6K, Visits: 38.0K
The performance depends on the GPU and the data size of the project
liebe Grüße vidi
Snarp Farkle
Snarp Farkle
Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)
Posts: 750, Visits: 3.4K
These are the Recommended System Requirements for iClone that I have which should be good to go by for all Reallusion Programs.
            NVIDIA                                          AMD
GeForce GTX 600 Series     OK     Radeon HD 8000 Series     OK
GeForce GTX 700 Series     OK     Radeon R5 M200 Series     OK
GeForce GTX 800 Series     OK     Radeon R7 M200 Series     OK
GeForce GTX 900 Series     OK     Radeon R9 M200 Series      ?
Recommended System Requirements:
(iClone will have better performance in below recommended environment)
  *  Intel i5 dual core CPU or higher - or AMD equivalent.
  *  8GB RAM or higher recommended.
  *  10GB free hard disk space or higher recommended.
  *  Display Resolution: 1920 x 1080 or higher.
  *  Graphics Card: NVidia Geforce GTX 600 Series/ AMD Radeon HD 7000 Series or higher.
  *  Video Memory: 2GB RAM or higher recommended.
  *  Video card compatible with Pixel Shader 3.0 recommended for optimized visual performance.
So if your system falls into this category then also make sure all your drivers are up to date, if they are then submit a support ticket would be my recommendation.
I also reinstall the latest updates if I'm having multiple program issues, not sure if it does anything at all but it's just something I do.
Kevin.S
Kevin.S
Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)Distinguished Member (8.9K reputation)
Last Active: 8 days ago
Posts: 1.2K, Visits: 71.7K
Your system specs are fine the problem you have is the lack of video memory" in short your video card is to weak to handle iclone. Any video card with only 2gigs of memory is not enough to run 85% of today's 3d software including games.the reality an 8 gig  video card should be the absolute min required spec for any 3d software program. Unfortunately  the only option you have is to upgrade your video card. I am not trying to be mean or anything just truthful.Smile
Cheers
Freelance Artist Kevin.S
https://forum.reallusion.com/uploads/images/57cedd8e-58c4-42ce-b2f4-9646.png https://forum.reallusion.com/uploads/images/5a59e070-66a0-4914-b0a5-b2dc.png
Email: animatemyart@gmail.com - Web Site:  www.animatemyart.com
Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)Distinguished Member (23.1K reputation)
Last Active: 15 hours ago
Posts: 12.7K, Visits: 22.4K
The OP is talking about CrazyTalk 8, which should have much less stringent requirements than iClone 6.
Minimum requirements (from the CT 8 FAQ page here):
Windows
64-bit Operating System: Windows 10/Windows 8/Windows 7 SP1
CPU: Dual core CPU or higher
Memory: 2 GB RAM or higher
Video Card: Nvidia GeForce 8 Series or higher/ATI HD 3000 Series or higher
Video Memory: 512MB RAM or higher
Display Resolution: 1024 x 768 or higher
Hard Disk Space: 5 GB free hard disk space or higher
In the CT7 FAQ it said something about Hyper-V, which should be disabled when installing. This may also apply to CT8.
This is known issue for Windows 8 in which the Hyper-V windows feature is turned on.  You may have Hyper-V as part of the Windows Phone SDK or Windows 8 Pro version is turned on Hyper-V by default.
Anyway, if your system has Hyper-V turned on, please help to disable it before you install Reallusion program & enabled it back after you've installed Reallusion program.
You may verify it as per below steps: -
1) Disable Hyper-V, steps on how to
2) Install Reallusion program.
3) Enable Hyper-V, same link as above on how to.
Other than a possible Hyper-V issue, your system should be powerful enough.
vidi
vidi
but what is with the Project size ?
Szene + 4 min Background Music in HQ can be too much
Better would be to make only the Lipsync
and  use a NLE for bring all thogether
liebe Grüße vidi
Kevin.S
Kevin.S
Windows 10   Evga and MSI both read on my system 1.5 gigs of memory usage just to open crazytalk 8. Add 1 picture and it jumps to 1.758 gigs of memory usage that's with absolutely no edits voices background etc. That's almost all your video memory used just to open crazytalk and add a picture. That leaves you with vary little video memory once you cap that 200ish free Megs your software will studder and chop badly. You can download MSI afterburner and monitor your video memory usage and see for yourself. MSI Afterburner https://gaming.msi.com/features/afterburner.
If you want to know if it is hardware related or software just run MSI afterburner, if you are not using all your video memory and crazytalk8 is chopping and studdering then its a software issue of some kind drivers system etc, if you are at full memory usage then its hardware. Lack of memory.
my 2 cents cheers
qacer
qacer
Thank you all for the replies! First I will try animagic's suggestion of disabling Hyper-V and re-install the software. If that doesn't work, then I'll start shopping for a video card. I had my eye on a Quadro K2200, but it appears that this may not be the ideal solution as I also use Sony Vegas Pro 13.
qacer
qacer
It turns out that I have Windows 10 Home, so by default I do not have Hyper-V installed. I decided to try MSI Afterburner. When I played my saved CrazyTalk project, the card memory showed 1125 MB. However, this seems to be the capped and it did not go further beyond this value.If my video card has 2 GB of memory, then what would an additional memory get me if the usage only maxes out at less than the card memory?
https://forum.reallusion.com/uploads/images/8f4b1b57-3f26-470f-91c5-c369.jpg
qacer
qacer
Uploading a zoomed in version of the Afterburner screenshot.
https://forum.reallusion.com/uploads/images/60ff12fd-530e-473b-9cfa-5b48.jpg
