CrazyTalk 8 slow performance on a 4 minute clip
Posted By qacer 10 Years Ago
qacer
qacer
Posted 10 Years Ago
Senior Member (316 reputation)Senior Member (316 reputation)Senior Member (316 reputation)Senior Member (316 reputation)Senior Member (316 reputation)Senior Member (316 reputation)Senior Member (316 reputation)Senior Member (316 reputation)Senior Member (316 reputation)
Last Active: 10 Years Ago
Posts: 9, Visits: 20
Hi all,
I have CrazyTalk 8. This weekend was the first time I've tried using it. I wanted to do a 2D actor talking head synced to a 4 minute song. I created a 2D actor from a picture. Then, I followed the lip syncing tutorial and ended up with the song as the background music and my voice-over controlling the lip syncs. I was disappointed with the performance. I could not properly modify the lip syncs because each time I hit play there was a delay with the actual animation preview. Basically, I hear the audio going, but the screen is frozen and delayed for a few seconds. It made figuring out where the vocals aligned with the actual frame difficult.
I'm not sure if there are any tips to optimize the performance, but I wanted to get a check whether my system specs are sufficient to be able to do a real time preview without any delays.
I currently have the following:
OS Name:    Microsoft Windows 10 Home
Version:   10.0.10586 Build 10586
OS Manufacturer:   Microsoft Corporation
System Manufacturer:    Dell Inc.
System Model:   XPS 8500
System Type:   x64-based PC
Processor:   Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM):   12.0 GB
Total Physical Memory:   12.0 GB
Available Physical Memory:   6.69 GB
Total Virtual Memory:   13.8 GB
Available Virtual Memory:   4.99 GB
Hyper-V - VM Monitor Mode Extensions   Yes
Hyper-V - Second Level Address Translation Extensions   Yes
Hyper-V - Virtualization Enabled in Firmware   Yes
Hyper-V - Data Execution Protection   Yes
Description:   Local Fixed Disk
Compressed:   No
File System:   NTFS
Size:   1.82 TB (1,999,316,709,376 bytes)
Free Space:   504.09 GB (541,259,653,120 bytes)
Adapter Type:   AMD Radeon Graphics Processor
Adapter Description:   AMD Radeon HD 7700 Series
Adapter RAM:   (2,147,483,648) bytes
Radeon Software Version - 16.3.2
Radeon Software Edition - Crimson
Graphics Chipset - AMD Radeon HD 7700 Series
Memory Size - 2048 MB
Memory Type - GDDR5
Core Clock - 1000 MHz
Windows Version - Windows 10 (64 bit)
System Memory - 12 GB
CPU Type - Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Are these specs sufficient?
If they are, how do I improve the performance of CrazyTalk 8, so I can replay the animation, background music, and voice-over smoothly during preview?
If these specs are not sufficient, would getting a different video card such as an Nvidia Quadro K2200 help?
Thanks!
Threaded View
Threaded View
Forum Post CrazyTalk 8 slow performance on a 4 minute clip By qacer ( 10 Years Ago )
Forum Post The performance depends on the GPU and the data size of the project By vidi ( 10 Years Ago )
Forum Post These are the Recommended System Requirements for iClone that I have... By Snarp Farkle ( 10 Years Ago )
Forum Post Your system specs are fine the problem you have is the lack of video... By Kevin.S ( 10 Years Ago )
Forum Post The OP is talking about CrazyTalk 8, which should have much less... By animagic ( 10 Years Ago )
Forum Post but what is with the Project size ? Szene + 4 min Background Music in... By vidi ( 10 Years Ago )
Forum Post Windows 10 Evga and MSI both read on my system 1.5 gigs of memory... By Kevin.S ( 10 Years Ago )
Forum Post Thank you all for the replies! First I will try animagic's suggestion... By qacer ( 10 Years Ago )
Forum Post It turns out that I have Windows 10 Home, so by default I do not have... By qacer ( 10 Years Ago )
Forum Post Uploading a zoomed in version of the Afterburner screenshot. By qacer ( 10 Years Ago )
Forum Post If you are looking for a new video card, stay away from Quadro cards... By animagic ( 10 Years Ago )
Forum Post [quote][b]animagic (8/23/2016)[/b][hr]If you are looking for a new... By qacer ( 10 Years Ago )
Forum Post The size of my project file is 62 MB. For this one, I opted to create... By qacer ( 10 Years Ago )
Forum Post When was the last time you defragmented your hard drives this is... By Kevin.S ( 10 Years Ago )
Forum Post I have Windows Defender running in the background. I also use a... By qacer ( 10 Years Ago )
Forum Post I was finally able to get a screen recording of the loading behavior.... By qacer ( 10 Years Ago )
Forum Post Here is a question have you tried to let someone else load your... By Kevin.S ( 10 Years Ago )
Forum Post I haven't gotten anyone else to try loading my project. I haven't... By qacer ( 10 Years Ago )
