bobdoyle
bobdoyle
Posted 17 Years Ago
Visits: 639
codewarrior (10/10/2009)
I cannot load any G3 Clonecloth Violet avatar. I get a dialog that says 'Failed to load the file. If this is a .vns file please switch to the avatar page and try again'. The G3 Clonecloth pack was installed fresh from the .EXE and not copied over from an iClone 3 installation. It installed successfully and reported itself as being 'installed successfully into your iClone'. The G3 male clonecloth pack was installed in exactly the same way, and those avatars load OK. As a clue, there are no thumbnails for the Violet avatars, whereas there are thumbnails for the Trey avatars. This same thing happened to me excatly, and for me, copying the iClone 3 folders over DID fix it.
Meet Bob Doyle World's Greatest (iClone) Interview with Bob Doyle
space man spiff
space man spiff
Posted 17 Years Ago
Last Active: 15 Years Ago
Visits: 207
Having a problem with the B170a and B170b motions. keeps saying 'cannot replace motion: Invalid file or avatar not compatible' I have tried re download and install, and have tried it on both Violetand ana avatars. Any ideas Pete
Vini Vidi Velcro I Came, I Saw, I Stuck Around.
aknzrdude
aknzrdude
Posted 17 Years Ago
Last Active: 6 Years Ago
Posts: 2.1K,
Visits: 11.0K
ditto - this is happning more often than not when opening projects and loading characters- need to find a fix for this - really hampers productivity when 7 out of every project i open results in a crash bobdoyle (10/11/2009)
codewarrior (10/10/2009) I cannot load any G3 Clonecloth Violet avatar. I get a dialog that says 'Failed to load the file. If this is a .vns file please switch to the avatar page and try again'.
As a clue, there are no thumbnails for the Violet avatars, whereas there are thumbnails for the Trey avatars.This same thing happened to me excatly, and for me, copying the iClone 3 folders over DID fix it.
Mick
Last Active: 16 Years Ago
Visits: 588
I cannot load any G3 Clonecloth Violet avatar. I get a dialog that says 'Failed to load the file. If this is a .vns file please switch to the avatar page and try again'. The G3 Clonecloth pack was installed fresh from the .EXE and not copied over from an iClone 3 installation. It installed successfully and reported itself as being 'installed successfully into your iClone'. The G3 male clonecloth pack was installed in exactly the same way, and those avatars load OK. As a clue, there are no thumbnails for the Violet avatars, whereas there are thumbnails for the Trey avatars. Hi, To solve this issue, you'll need to re-download the installation package of the content packs, and then you are able to re-install them into iClone4. First of all, you have to login premium member account via the following link. http://www.reallusion.com/member/program/memberreg.asp Steps: 1) Login your member: http://www.reallusion.com/member/program/memberreg.asp 2) The version of iClone will show on the web page 3) Click on “Order History” tab 4) You can find the download link.
Yours sincerely,
Mick Technical Support Reallusion Inc. www.reallusion.com
Illustrator Cathy
Illustrator Cathy
Posted 17 Years Ago
Last Active: 11 Years Ago
Visits: 1.7K
Yes - I just bought the G3 Clone Cloth packs, downloaded and installed both tonight - I can't replicate the malfunction. All of Violet's stuff works for me. I think this goes for other content as well, as I have not been able to replicate other complaints I've been reading. I did fresh installs of all my content - City Elements, Medieval Village, Natural Human, vehicles, etc. I don't get the 'Trial' label and it all works. But - I'm not working with projects originally made with iClone3 - so that may be another issue all together. Hope this helps. Cathy :hehe:
Just click on the graphic to go there.
Galfridus
Galfridus
Posted 17 Years Ago
Visits: 2.2K
G2 Natural Human Base avatars. Cannot select Head in Edit motion panel. Even if an IC4 head is substituted on an G2NHB character it still cannot be selected to edit the movement from the panel. Other parts on G2NHBcan be animated as normal. Other G2 characters seem to operate as normal including the head.
Geoff.
shygirl
shygirl
Posted 17 Years Ago
Last Active: 7 Years Ago
Posts: 1.3K,
Visits: 8.3K
Hi Geoff, I reported this problem to Reallusion last week and Mick replied almost immediately. I also sent them some info they requested....so it is being looked :) Hope this provides some reassurance. Shy :)
"O wad some Power the gift tae gie us, to see oursels as ithers see us!"
Galfridus
Galfridus
Posted 17 Years Ago
Visits: 2.2K
Thanks for that Shygirl. Good to know that it's not just my computer being awkward. :) Having now worked my way through every Natural Base Character including the set with realistic texture the only exception to the problem seems to be Sarah. Her head can be edited for movement.
Geoff.
Paumanok West
Paumanok West
Posted 17 Years Ago
Last Active: 12 Years Ago
Posts: 2.5K,
Visits: 7.0K
In iC4, objects often use negatives of their opacity mask when loaded from disc. I have noticed this negative-of-the-opacity-mask behavior in several objects. There is no clear discernable pattern, but I have so far noticed it in objects ATTACHed to the avatar. In the following illustration, Fred was NOT using Maybelline.
General Picture - animating now to life itself(tm) Member of Content Wizards
Posted 17 Years Ago
Posts: 23.1K,
Visits: 36.6K
hurlook (10/7/2009)
Hello Peter, after two days of testing on two computers here's my list of problems: invalid serial number, but it seems registered ok when i go to my premium account, all ic 3.2 content imported in IC4 has a watermark or the trial mark 4, ic 2,5 loads fine. All Reallusion content purchased via Backstage, motions, props, characters etc,,,has a watermark. Motions purchased in Backstage starting with the letter B ( older motions ) are working fine , motions with the letter C, created for ic3 occupations pack characters, appear as a trial or with the buy at reallusion message. Packs working great in ic3, like Dreamgirls, ww 2 pack, Rock band, total materials, Films set props, City Blocks etc... are just trial in ic4, if i try to save them a message tells me to buy the content! Gsg 9 character has problem around the neck, as seen on another message here. My Custom projects, hair and motions created in ic 3 appear like trial, all with watermark, so i guess there's some kind of compatibility issues between ic 3 and 4, i hope Reallusion will soon release a patch to fix all this mess, All the best, Stefano Hi Stefano, All the problems you are having with the trial stamps, watermarks etc look to be because of the serial number registration issue. If you haven't got this sorted out yet please contact Support so you can get the serial number correctly registered. Thanks. http://www.reallusion.com/CustomerSupport/User/QForm.aspx.
