Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
UPDATE: The problems with checking out should now be resolved. Thank you for your patience. :)
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
tbarry (11/8/2010) Hi there..... anybody else having problem making purchases from the Iclone content store since yesterday? I keep getting this message over and over after I place an item in the shopping cart and then try to proceed to checkout:
"An error has occurred
We are unable to process your request at this time. Please try again later."
Is this just me? Thanks - TodHi Tod, Apologies for the problems purchasing content today. There is currently an ongoing issue that is affecting the checkout of orders. This is being investigated and normal service should be resumed very soon now.
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
RiViT (11/8/2010)
Peter (RL) (11/8/2010) Thanks for your feedback on the rotation issue.You're welcome, Peter. Take a look at the images I've linked to below (scroll to the right in the images to see what I've circled in the Modify Panel). Here are the steps I took to get these results: - frame 10, Y rotation: 30 - frame 20, Y rotation: 60 - frame 30, Y rotation: 90 - frame 40, Y rotation: 120 As soon as I clicked on frame 50, the Y rotation for frame 40 changed to 60. At the same time, the rotation values for X and Z in frame 40 spontaneously changed to 180. You can see from the snapshots of frames 20 and 40 that there is a world of difference in the positions of the 3D block. I urge you to try this for yourself. Image 1Image 2Peter (RL) (11/8/2010) For example typing in 0, 240, 0 is the same as 180, 300, 180.I'm not sure if you're saying that iClone has redefined the circle or if we're talking apples and oranges. Perhaps you mean that a symmetrical object LOOKS as if it's in the same orientation if it's at 0 or 180 degrees, but the same doesn't apply for the same object between 240 and 300. Hi Ron, Thanks for explaining more. My point was that if you continue to add 30 degrees at each 10 frame interval until you complete a full circle - your animation will still be correct even though the numbers will have changed to reflect the way iClone is handling them. Try doing this with an avatar or a clearly marked prop. Frame 10 - 0.30.0 Frame 20 - 0.60.0 Frame 30 - 0.90.0 Frame 40 - 0.120.0 (changes to 180.60.180) Frame 50 - 0.150.0 (changes to 180.30.180) Frame 60 - 0.180.0 (changes to 180.00.180) Frame 70 - 0.210.0 (changes to 180.330.180) Frame 80 - 0.240.0 (changes to 180.300.180) Frame 90 - 0.270.0 Frame 100 - 0.300.0 Frame 110 - 0.330.0 Frame 120 - 0.360.0 Once completed and you press Play your avatar or prop will make a complete rotation and even though the numbers between frame 40 and 80 have flipped, the animation will still play correctly. Give it a try and see how you get on. :)
tbarry
tbarry
Posted 16 Years Ago
Last Active: 15 Years Ago
Visits: 79
rontarrant
rontarrant
Posted 16 Years Ago
Last Active: 11 Years Ago
Visits: 571
- Ron T.
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
RiViT (11/4/2010) I think I may have found an issue with rotation. Please forgive me if this has already been reported; I did a search of the forum and found nothing about it.
This happens with 3D Blocks and only when rotating around the Y axis.Hi Ron.. Thanks for your feedback on the rotation issue. You are right that iClone will change the input for certain transform settings but it should be remembered that both sets of figures are exactly the same positioning in iClone. For example typing in 0, 240, 0 is the same as 180, 300, 180. So although you may see the numbers change in the transform box the positioning of the object should remain the same and your animation should remain unaffected. Is this your experience so far?
mathahn
mathahn
Posted 16 Years Ago
Last Active: 13 Years Ago
Visits: 333
I solved the problem with sound, but the playback in editing mode is still herky-jerky and when I export, the sound is not in synch. Any ideas? Thanks.
rontarrant
rontarrant
Posted 16 Years Ago
Visits: 571
To recreate this, drop any 3D Block into a new project, open the Timeline and the Transform track for the object.
Every twenty frames or so, change the Y axis by any amount between 30 and 60. Do this up to frame 100.
Now go back and look at the rotation values in the key frames you've set. They will not all remain at the values set... unless I'm the only one having this problem.
It seems the greater the difference between the rotation in one frame and the next, the more keys will have been changed by the time you get to frame 100.
EDIT:
The value for the Z rotation will also change sometimes, even though no value has been set.
EDIT 2010-11-07:
I tried this again yesterday after a clean reboot, just to be sure. No other software was running. Here is the test I performed: - new Project - drag in a ball - open the timeline and click Transform to show rotation/scale/move keys - set keys of these values at these frames: - frame 20: Y rotation 20 - frame 40: Y rotation 40 - frame 60: Y rotation 60 - frame 80: Y rotation 80 - frame 100: Y rotation 100
Then I clicked on each of the keyframes I'd set. They were fine. Then I clicked on each again, and there were X and Z rotations of 180 set in frame 100 (which I hadn't set).
I then took out the X and Z rotations and set these keys: - frame 20: Y rotation 30 - frame 40: Y rotation 60 - frame 60: Y rotation 90 - frame 80: Y rotation 120 - frame 100: Y rotation 150
Clicking back through the keys, I found this: - frame 20: Y rotation 30 (OK) - frame 40: Y rotation 60 (OK) - frame 60: Y rotation 90 (OK) - frame 80: Y rotation 60, X = 180, Z = 180 (RESET by iClone) - frame 100: Y rotation 30, X = 180, Z = 180 (RESET by iClone)
Is no one else having this problem?
- Ron T.
Seeker769
Seeker769
Posted 16 Years Ago
Visits: 1.1K
Hi, This might be of a little more help, open 3DX4 and press F1, now go to the sections I've circled. This explains what to do if unify is not getting the desired results.
Hopefuly this will make things easier. Happy modding, Chris
iClone training resources https://forum.reallusion.com/Topic70771-161-1.aspx
Magique
Magique
Posted 16 Years Ago
Visits: 1.4K
Yes, thank you. I didn't realize this was the same thing. That will work for me. I still wish I knew why the unify normals doesn't work though.
