iClone4 - Issues Thread
Posted By Peter (RL) 17 Years Ago
Rated 3 stars based on 3 votes.
colour
colour
Posted 14 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
markk1 (11/25/2012)
Recently I have upgraded my computer with new MB, Graphics card and Ram (4gig). I installed my original HD with IC4 and 3D exchange onto the new machine. Running XP with SP3.
IC4.31 loads the splash screen, does some loading then crashes to desktop. 3Dexchange just crashes to desktop.
Any clues? Thanks
As I recall (Correctly/incorrectly), if you re-build your PC ro the extent you've done (Especilly the MOBO), XP sees your PC as a new one &  needs to be re-Registerd with Microsoft.
However, this might not be your case if everything-else functions ok & you don't get a Windows XP prompt reminding you to Register within 30 days.
The other side of the coin could be that iC4 & 3DXchange are seeing your PC as a new one.
Just a couple of thoughts re; the Software side.
Hardware - Ensure that the RAM you've Installed is exactly the same rating for all sticks & compatible with your new MOBO.
If you've Saved (Backed-up) iC4 & 3DXchange  Programs Install Setup EXE Files, a Reinstall of those "might" fix it.
Anyone-else?
markk1
markk1
Posted 14 Years Ago
Veteran Member (688 reputation)Veteran Member (688 reputation)Veteran Member (688 reputation)Veteran Member (688 reputation)Veteran Member (688 reputation)Veteran Member (688 reputation)Veteran Member (688 reputation)Veteran Member (688 reputation)Veteran Member (688 reputation)
Last Active: 7 Years Ago
Posts: 37, Visits: 387
I installed my hard drive to this new MoBo and sorted out the new hardware issues with xp.
All my original programs ran without having to reinstall them, expect the reallusion ones.
I will try to install iclone again and see that fixes it. I already have all the content files installed. I really don't want to have to go through the process reinstalling again.
I have uninstalled and reinstalled Iclone and now loads up properly. Thanks.
colour
colour
Posted 14 Years Ago
markk1 (11/26/2012)
Glad it's fixed:)
BTW - All of the Programs I have Installed, when Running the SETUP EXE File, give options to Repair / Modify or Uninstall. Apart from iClone, which can only be Re-Installed:ermm:
Selecting the Repair Option usually Fixes the Loading Splash Screen Hang / Crash to Desktop in the other Programs. Reallusion need to get up to speed re; the basics of  Program Delivery.:ermm:
mathahn
mathahn
Posted 13 Years Ago
Last Active: 13 Years Ago
Posts: 116, Visits: 333
Sometimes when I have two characters and I give one character an animation (most recently it was the holding a glass pose, but it has happened with other animations) the character flies away. How do I stop this from happening?
mathahn
mathahn
Posted 13 Years Ago
Thanks.
colour
colour
Posted 13 Years Ago
mathahn (1/9/2013)
This is a fairly common problem.
Right-Clicking on a Character & Selecting; Delete All Animatioin in the Context Menu, before you Apply a Motion, "Might" prevent it from happening.
If you Select the Character in Scene Manager & then the Home Toolbar Icon after the Character has disappeared, you'll see that the Character has been positioined directly on the Grid World Axis, where it will Perform the Motion you applied.. This is what happens when you Apply some Motions to some Characters.
To get the Character back-again, Select the Character in Scene Manager & then Link/Postion it to another Object in the Scene. Unlink & Re-postion. Play-back. The Motion should now Play from the correct Position.
Anyone-else?
mathahn
mathahn
Posted 13 Years Ago
I shot a scene, but when I rendered it, the animations and the voices and the FX are out of sync. How do I get the rendering to sync correctly? Thanks.
