iClone4 - Issues Thread
Posted By Peter (RL) 17 Years Ago
Rated 3 stars based on 3 votes.
Galfridus
Galfridus
Posted 17 Years Ago
Posts: 727, Visits: 2.2K
Just spent some time transferring content over to IC4. The Trial mark is a real pain. Is there a quicker way to get rid of it than loading each individual item into the preview window whilst on-line?
These 2 avatars seem to display a problem which does not occur on any of the many others I have.Their faces are detached and remain locked in a fixed position when the avatar is moved.;)
B214 May Clone Gown face fixed at central position normal height.
B168 Grooms Man face fixed central position on the floor.
Geoff.
https://forum.reallusion.com/uploads/images/ba17ca1f-2bbe-4b61-819c-6bdf.png
DELETED2
DELETED2
Posted 17 Years Ago
Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)
Group: Banned Members
Last Active: 11 Years Ago
Posts: 2.4K, Visits: 6.1K
We DEFINITELY need "constant quality" and 100% Export on FLV format output.
I dont know how the keyframes are set but it seems about every 10 frames or so theres a reset compression jump thing. I used to kill this by disallowing autocompression and using constant quality rather than variable acording to the frames' makeup.
Does thks make sense?
Sophia
Sophia
Posted 17 Years Ago
Last Active: 12 Years Ago
Posts: 12, Visits: 82
This is only a tiny problem, but I thought I'd report it anyway. One part of the screen is black, as seen in the screenshot. This is consistent and happens every time I open iClone, however when I resize the screen by dragging the divider, the black spot disappears.
Posted 17 Years Ago
Posts: 23.1K, Visits: 36.6K
thompsongeoff (10/9/2009)
Geoff.
While annoying to see, the Trial stamp doesn't affect your use of the content. The messages will go as you use the individual items over time.
The corrupted heads of some older avatars can be corrected by loading a new head as was previously mentioned. This is a good workaround while a fix is found.
Posted 17 Years Ago
Posts: 5.7K, Visits: 26.5K
Using the Text Particle in iClone 4 doesn't work.
Here's a screen shot after adding a Text Particle:
After placing a Tick under Show, this is what is shown:
This was done using the files installed with IC4.
The files installed with IC3 work correctly in IC3.
Galfridus
Galfridus
Posted 17 Years Ago
Peter Edwards
Forum Moderator
Thanks for the Head “work round” Peter. I hadn't seen a reference to this before but it certainly works.
The trial mark continues to effect the way I work. IClone is installed on my laptop so that I can use it when I'm not at home and connected to the internet. Use of “trial” items when not connected to the internet result in a watermark. Not good for content I have previously paid for and installed on my computer.
Geoff.
aknzrdude
aknzrdude
Posted 17 Years Ago
Last Active: 6 Years Ago
Posts: 2.1K, Visits: 11.0K
well frustration level is creeping up - it feels this is less stable than iC3 - when it comes to opening iC3 projects, i often get crashes, when i try to replace an avatar - i get a 'Raise Left Cheek' error
spent the better part of the night trying to open projects so i cen render them out but so far my iC4 crashed 20x - yes you heard that - can't get any work done coz of the constant crashing
Cricky
Cricky
Posted 17 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
MelHolden (10/9/2009)
Is there a way to texture Jimmy Tune.
Texture the Skin.
Kind of like the old way of doing G1 characters except the skin areas are defined by region such as Upper, Lower, Shoes, etc., and painting a texture fills that regional area only using the Paint Bucket.
SKYPE ID: rc.650
Cricky
Cricky
Posted 17 Years Ago
wires (10/10/2009)
I know this may be something you've already done, but perhaps you haven't. I re-installed almost every pack again from the original packages...a pain it can be, but it solved the majority of the problems I was having. There were only a few packages which were designed for installation to a different iClone version that would not install, and or would not import or transfer in. Most of my issues have dissolved, and I sent remarks to support directly to allow them time to check the packages that would not cooperate...those I haven't sent, I will.
Screen Shot of the Text Particles I get in iClone is attached...all 3 particles were added at once.
SKYPE ID: rc.650
codewarrior
codewarrior
Posted 17 Years Ago
Veteran Member (778 reputation)Veteran Member (778 reputation)Veteran Member (778 reputation)Veteran Member (778 reputation)Veteran Member (778 reputation)Veteran Member (778 reputation)Veteran Member (778 reputation)Veteran Member (778 reputation)Veteran Member (778 reputation)
Posts: 36, Visits: 116
Fantasy Pack characters have teeth in wrong place and if head is edited even slightly, eyeballs go missing and mouths lose shape.
See the teeth in wrong place on import with no editing yet.
After editing eye width very slightly in head->Faces->eyes the eyes dissapear leaving empty sockets. After this, it's impossible to get any eyeballs back. It's not just editing eye width.. any edit to the head will make the eyeballs dissapear. It is not just the Darkonia model. All of the Fantasy Pack models have this problem.
Pete Patterson - Contract Programmer http://ideajuice.com
Ideajuice Consulting Services
Need code???
Decades of programming experience. Working with 3D since the 1980's. Fluent in C# and Javascript.
