iClone4 - Issues Thread
Posted By Peter (RL) 17 Years Ago
Rated 3 stars based on 3 votes.
colour
colour
Posted 15 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
bluemidget666 (6/16/2011)
Thank you I will have a go at that when i get chance:)
Yeahhh works for me ! Thanks#
Thanks, both:)
But doesn't work for me.
In fact the motion won't even start now.:ermm:
No worries - I'll figure it out - Eventually.
No Coke or cigar - Yet;)
bluemidget666
bluemidget666
Posted 15 Years Ago
Last Active: 10 Years Ago
Posts: 3.5K, Visits: 13.8K
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
Cricky
Cricky
Posted 15 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
You owe me a Coke!
duchess110 (6/16/2011)
Looked at what my river did and like your stopped at approx 535.
So I did a right click on the river which is attached to the ground/floor selected perform -1w001 or something like that it is called then dragged that to the very start and then did a loop and it then played all the way to the end.
SKYPE ID: rc.650
duchess110
duchess110
Posted 15 Years Ago
Last Active: 6 Years Ago
Posts: 2.0K, Visits: 15.5K
Cricky and I posted together but with similar/same suggestion.
Duchess Designs Store
Cricky
Cricky
Posted 15 Years Ago
In answer to the issue of the water flow:
Look in the Scene Manager for the River Course A01 prop.
There is a flow attached to it as a sub-node. The top node River Course has no performs available.
If you Right Click on the Sub-Node ( River 01 ) you will get a perform command; Choose the perform command and the water will apply a "IW001" to the River Course on the timeline...then you can stretch it, shrink it, or loop it as needed to speed up, slow down or repeat the water flow as needed.
colour (6/16/2011)
bluemidget666 (5/5/2011)
Hello
Need help I am using River Course A01 from the Medieval Village set but after 8 seconds of animation the water animation stops any Ideas what I am doing wrong.. Thanks
Anyone else having this problem
Yes - Me.River flow stops at 525 frames:unsure:
Only just arrainging / re-arrainging& testingprops at the moment - So not fussed.
I'll Post a workaround if & when I get it fixed, if I remember.
Initial thoghts are;
1) Adding other parts of the River course, either in or out of view, might fix it.
2) Only 2 Keyfranes at Frame 1 for Transform & Material for River.Playing around with Transform Keys,might fix it.
3) If no Fix, using "Empty" River Course B01 & then applyinmg Watewrflow Propsmight be an alternative.
SKYPE ID: rc.650
bluemidget666
bluemidget666
Posted 15 Years Ago
Hi
I have been on to support about this issue and they are looking into fixing this ... though this was a month or so ago.. I have tried using water to replace the default river water but didnt like the results as much...
colour
colour
Posted 15 Years Ago
Hello
Yes - Me. River flow stops at 525 frames:unsure:
Only just arrainging / re-arrainging & testing props at the moment - So not fussed.
2) Only 2 Keyfranes at Frame 1 for Transform & Material for River. Playing around with Transform Keys, might fix it.
3) If no Fix, using "Empty" River Course B01 & then applyinmg Watewrflow Props might be an alternative.
Magique
Magique
Posted 15 Years Ago
Posts: 315, Visits: 1.4K
I've never received any response to the issue I reported with Image Based Lighting. With a really large scene when I select IBL Sunny, it creates a skydome of 250 size and applies lighting within the dome and ignores the rest of the scene. Scaling the dome up afterwards doesn't help. The lighting seems to be baked into the texturing permanently after first application. Here is a new screenshot.
bluemidget666
bluemidget666
Posted 15 Years Ago
Hello
3DStory
3DStory
Posted 15 Years Ago
Posts: 272, Visits: 5.7K
yes, it is possible. Both errors happened when I was working with Mr. Pinhead. I guess he is nervous to appear in my first iClone movie...frankly I can't blame him ;)
                https://forum.reallusion.com/Uploads/Images/5b5f10b8-8e56-40e9-affb-d47d.gif
