Posted 15 Years Ago
Posts: 23.1K,
Visits: 36.6K
Pat_20110615082725781 (6/17/2011)
:hehe:I am trying IClone 4, but purchased the Mr Pose & friends, yes I do have issues with the package: - because, if I was going to purchase it, it would be to make logos, widgets on web-sites the output is very important and from what I see it output the results to an avi which is huge (even with the most simplistic one), the results is for the web-site waiting too long for displaying its contents is there any other type of output (pages written in html or .net 2010)?
- I do not understand the Mr Pose & friends, I purchased them because it does say: animated ready, so I thought I would then only have to modify it slightly to fit my purposes, but I cannot see any of Mr Pose advertised with that package which make me regret to have purchased it!
- I would like to purchase a animation type of package but it needs to have what it claims to have, be user friendly and capable to render the results into an appropriate format so one can use it, it also has to have a good support, so far I have not seen this happening.
- A trial version is the most important part of a package as people decides in function of what the package can do not just what it promises it will do
Apologies but I don't really understand some of the points you are making. When it comes to video formats iClone4 can export to avi, wmv, rm, mp4 and flash. It can also export sequence image in a variety of formats. You also have the option of iwidget and popVideos. All of which can have various resolutions including HD. It is not limited to just AVI. Which video format are you wanting to use? Sadly I also don't understand the problems you are having with Mr Pose. Can you explain what you want to do with the character that you so far have been unable. Perhaps we can help. :)
Posted 15 Years Ago
Posts: 23.1K,
Visits: 36.6K
tscott (6/15/2011) I've never received any response to the issue I reported with Image Based Lighting. With a really large scene when I select IBL Sunny, it creates a skydome of 250 size and applies lighting within the dome and ignores the rest of the scene. Scaling the dome up afterwards doesn't help. The lighting seems to be baked into the texturing permanently after first application. Here is a new screenshot.You should be able to adjust the global IBL scale under Atmosphere. Then select the Sky in Scene Manager and adjust the scale of this to match the IBL. Give this a try and see if it helps solve your problem.
Posted 15 Years Ago
Last Active: 5 Months Ago
Posts: 15.8K,
Visits: 31.4K
markk1 (6/17/2011) Having fun with Iclone Pro 4.
I having been exporting videos with audio attached to them. I have noticed wmv supports 48khz audio sample rate. Avi and Mp4 for pc renders/exports the audio at 32khz.
My requirements for certain projects that I am doing requires 44.1 khz. Apart from just exporting the video to a video editor and then add the audio afterwords, how do I overcome this limitation?
Thanks.If you have a video editor there should be no need to separate audio and video, you would just render to the required audio sample frequency (Sony Vegas does that; I often use mixed format audio). An alternative is to use the free Any Video Converter. I'm not 100% certain, but it provides settings for the video and audio output characteristics, so you should be able to adjust the audio that way.
bluemidget666
bluemidget666
Posted 15 Years Ago
Last Active: 10 Years Ago
Posts: 3.5K,
Visits: 13.8K
@Pat Iclone can output many formats what format do you want ?
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
Posted 15 Years Ago
Last Active: 15 Years Ago
Visits: 2
markk1
markk1
Posted 15 Years Ago
Last Active: 7 Years Ago
Visits: 387
Thanks.
colour
colour
Posted 15 Years Ago
Posts: 5.2K,
Visits: 8.1K
Paumanok West (6/16/2011)
colour (6/16/2011) Just typed a long quoted Reply which got Deleted - Server Error - Typical.colour, for a long time, I've had the server reject a post when it took longer to compose than the server wants to wait. It sets a timeout after which it refuses to accept a post. If you are working on a post for more a short while, better copy it to your clipboard so you can easily repost. (This is apparently a feature, not a bug...!) Thanks for the SP:)
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS. New Pinhead Website & Project to be announced in September 2015 -----------------------------------------------------------------------------------------
Paumanok West
Paumanok West
Posted 15 Years Ago
Last Active: 12 Years Ago
Posts: 2.5K,
Visits: 7.0K
General Picture - animating now to life itself(tm) Member of Content Wizards
colour
colour
Posted 15 Years Ago
Posts: 5.2K,
Visits: 8.1K
bluemidget666
bluemidget666
Posted 15 Years Ago
Posts: 3.5K,
Visits: 13.8K
Hi colour By any chance did you add the river to tarain then convert it back to a prop as I could not get them working after that...
