iClone4 - Issues Thread
Posted By Peter (RL) 17 Years Ago
Rated 3 stars based on 3 votes.
Gogol Bordello
Gogol Bordello
Posted 16 Years Ago
Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)
Posts: 7, Visits: 1.1K
Can you do a script (Persona) for me? I want to check.
Sen
Sen
Posted 16 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Posts: 2.8K, Visits: 28.5K
First make sure , motion are installed into Horse_motion/arabian horse/move/walk_A .
Try this persona base free ti iclone 4 :
http://tootiny.net/r5hy2d
CGTRADER
Gogol Bordello
Gogol Bordello
Posted 16 Years Ago
Many thanks! It works.
Posted 16 Years Ago
Posts: 23.1K, Visits: 36.6K
shapovaldom (12/12/2010)
Hi!
There is a problem with the command
of move (Walk A, B) in a package "Creature Base-Horse and Tack Theme Pack" . After application of this command the program stands a crash closed.
Version IClone 4.3.1929.1
I have not been able to reproduce the problems you are having with my installation of this pack. Have you tried downloading the pack again and reinstalling? This may well solve your problem.
Gogol Bordello
Gogol Bordello
Posted 16 Years Ago
Ok, thank you. I will try and will write a result.
tricorne
tricorne
Posted 16 Years Ago
New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)
Last Active: 15 Years Ago
Posts: 3, Visits: 36
I've just purchased IC4.3PRO and am having the same problem with the Resource Pack - cannot instal it. Has anyone got any tips?
Posted 16 Years Ago
tricorne (12/16/2010)
The version number of iClone you have installed has to match that of the resource pack to allow it to install. Make sure that you are running the very latest version of iClone 4.3.1929.1 and then download the latest resource pack from your account (click Bonus & Upgrade).
This should then install fine. :)
JasonJ68
JasonJ68
Posted 15 Years Ago
Last Active: 5 Months Ago
Posts: 295, Visits: 2.4K
Is this a bug?: Max Real-time Map Size affects exported files
Under the Preferences control panel, I thought that the "Max Realtime Map Size" did not affect the export of videos or images.
Since it's not easy here to attach images, please try the following experiment:
0. Open any project and zoom in onto an object.
1. In the iClone control panel, set Max Realtime Map size to 256x256 and output a jpg of any size.
2. Without changing the camera angle, set Max Realtime Map to 8192x8192 and output the same size jpg.
If you compare the two outputs, do you see a difference?
Posted 15 Years Ago
jasonjbrown (2/5/2011)
You have to remember that iClone works in a realtime enviroment so any changes made to the realtime map settings will affect your final output. This is normal and the way it is meant to work. :)
JasonJ68
JasonJ68
Posted 15 Years Ago
THanks for the reply... but I could not find that information anywhere in the help files of iClone?
The help files indicate that any final output will be in the highest quality possible (unless you check the box "Preview Render") -- that also seems to imply using the highest quality texture maps available.
You should make this distinction very clear in the help files, please.
Without it, you are totally misleading your customers about render quality! :angry:
