How To Install The Indigo RT Suite
Posted By Peter (RL) 11 Years Ago
Posted 11 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi Everyone,
It appears many of you are having problems installing the Indigo Suite (Indigo Plugin and Indigo RT For iClone). To resolve the problems please take a few minutes to check out the FAQ links below.
Important: Installation Order
iClone 6
Indigo Plugin (iClone 6 should not be running)
Indigo RT For iClone 6
How to install the iClone Indigo Render Plug-in?
http://faq.reallusion.com/index.php?action=article&cat_id=011001007001&id=713&lang=
How to install Indigo RT for iClone?
http://faq.reallusion.com/index.php?action=article&cat_id=011001007001&id=714&lang=
And if you are having problems locating your Indigo RT For iClone activation code, please see below.
How to get "Indigo RT for iClone" activation key? (Step 3)
http://faq.reallusion.com/index.php?action=article&cat_id=001001&id=199&lang=
Threaded View
Threaded View
Forum Post How To Install The Indigo RT Suite By Peter (RL) ( 11 Years Ago )
Forum Post Hi Peter thanks for the info. I have tried this multiple times still... By Virtual Architec ( 11 Years Ago )
Forum Post What I did different and what seems to work is install Indigo RT for... By animagic ( 11 Years Ago )
Forum Post Hi, i have also the same problem with Indigo RT. I have tried... By brand468 ( 11 Years Ago )
Forum Post I found that when I copied and pasted the license key for the Render... By brrymchlsn ( 11 Years Ago )
Forum Post Same problem here with iclone Indigo RT. Installed everything, put in... By lvandepaer ( 11 Years Ago )
Forum Post I just received all this software and installed it and everything says... By Sigurd8 ( 11 Years Ago )
Forum Post i have been trying for days and days to resolve this and cannot!!!!!... By richard666 ( 10 Years Ago )
Forum Post [quote][b]richard666 (1/5/2015)[/b][hr]i have been trying for days and... By Peter (RL) ( 10 Years Ago )
Forum Post peter thank you for replying AND solving this issue. i am no... By richard666 ( 10 Years Ago )
Forum Post [quote][b]Peter (RL) (1/6/2015)[/b] In iClone 6 go to "Plugins >... By hattori kun ( 10 Years Ago )
Forum Post Hi Peter, my Indigo render plugin has disappeared from the menu bar in... By pi-qui ( 10 Years Ago )
Forum Post [quote][b]pi-qui (10/7/2015)[/b][hr]Hi Peter, my Indigo render plugin... By Peter (RL) ( 10 Years Ago )
Forum Post I tried everything described here, but the Indigo plugin is no longer... By pi-qui ( 10 Years Ago )
Forum Post Hi Peter. Thanks for the Hint but it does not work with my iclone... By cducharme ( 10 Years Ago )
Forum Post [quote][b]cducharme (1/5/2015)[/b][hr]Hi Peter. Thanks for the Hint... By Peter (RL) ( 10 Years Ago )
Forum Post I have been having the same problem as everyone else. I tried the... By dwcook281 ( 10 Years Ago )
Forum Post I was not able to locate my activation key. In my emails I only see... By 45thdiv ( 10 Years Ago )
Forum Post [quote][b]45thdiv (1/13/2015)[/b][hr]I was not able to locate my... By wires ( 10 Years Ago )
Forum Post [quote]The email should contain 3 "serial numbers", one for iClone 6,... By 45thdiv ( 10 Years Ago )
Forum Post So, I gave in and bought Indigo and after a few attempts, I was told... By Lost Filmmaker ( 10 Years Ago )
Forum Post [quote][b]Lost Filmmaker (1/13/2015)[/b][hr]So, I gave in and bought... By theschemer ( 10 Years Ago )
Forum Post I can't find C:\Program Files\Indigo RT\ By Lost Filmmaker ( 10 Years Ago )
Forum Post [quote][b]Lost Filmmaker (1/13/2015)[/b][hr]I can't find C:\Program... By Lost Filmmaker ( 10 Years Ago )
Forum Post [quote][b]Lost Filmmaker (1/14/2015)[/b][hr][quote][b]Lost Filmmaker... By wires ( 10 Years Ago )
Forum Post [quote][b]wires (1/14/2015)[/b][hr][quote][b]Lost Filmmaker... By Lost Filmmaker ( 10 Years Ago )
Forum Post I just checked and I do have RT installed, but it has Trial Version... By 45thdiv ( 10 Years Ago )
Forum Post Well, after all is done, I went to start iClones6 and "Load Resource... By 45thdiv ( 10 Years Ago )
Forum Post Well, here is another interesting thing. I have a new machine running... By 45thdiv ( 10 Years Ago )
Forum Post I have everything installed, and I followed the steps. I added my... By 45thdiv ( 10 Years Ago )
Forum Post All my applications look like they are working now. Next, on to... By 45thdiv ( 10 Years Ago )
Forum Post Success, the redownload did the job. By Lost Filmmaker ( 10 Years Ago )
Forum Post 6.02 seems to be unsupported. I kept reinstalling but couldn't see the... By hattori kun ( 10 Years Ago )
Forum Post I had the same problems installing Indigo as many have reported here.... By prairiemain ( 10 Years Ago )
Forum Post iC6 installed and work perfectly all settings are correct and can send... By Lawsuit Pending Records ( 10 Years Ago )
Forum Post [quote][b]Lawsuit Pending Records (2/24/2015)[/b][hr]iC6 installed and... By Peter (RL) ( 10 Years Ago )
Forum Post Hi Peter I am using the Indigo for iClone version I received a... By Lawsuit Pending Records ( 10 Years Ago )
Forum Post When you see all those gibber-jabber numbers in the trial version of... By leshenderson ( 10 Years Ago )
Forum Post HI Removed the plugin and the Indigo RT Software. Installed again... By Lawsuit Pending Records ( 10 Years Ago )
Forum Post [Moderator Removed] - Posting profanity is against forum rules.... By JC Weatherby ( 10 Years Ago )
Forum Post Reallusion Support kindly explained that the SERIAL NUMBER provided... By JC Weatherby ( 10 Years Ago )
Forum Post I don't know what I did the first time I install the plugin but i got... By msjaebea ( 10 Years Ago )
Forum Post I tried everything for once I even followed the instructions, it was... By Lawsuit Pending Records ( 10 Years Ago )
Forum Post Hello, For install Indigo with iClone 6.1, the only way i found. 1 )... By guy launay ( 10 Years Ago )
Forum Post Hi I installed iClone 6, Indigo Render Plugin and Indigo RT for iClone... By cducharme ( 10 Years Ago )
Forum Post [quote][b]cducharme (6/13/2015)[/b][hr]Hi I installed iClone 6, Indigo... By Lawsuit Pending Records ( 10 Years Ago )
Forum Post Thanks for Your advice. I did uninstall Indigo and redo the install... By cducharme ( 10 Years Ago )
Forum Post I have IC 7 installed now and need to install the Indigo RT and IC 7... By Alien Maniac ( 8 Years Ago )
Forum Post [quote][b]Space Rider (12/6/2017)[/b][hr]I have IC 7 installed now and... By TonyDPrime ( 8 Years Ago )
