How To Install The Indigo RT Suite
Posted By Peter (RL) 10 Years Ago
Posted 10 Years Ago
Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)
Posts: 23.1K, Visits: 36.6K
Hi Everyone,
It appears many of you are having problems installing the Indigo Suite (Indigo Plugin and Indigo RT For iClone). To resolve the problems please take a few minutes to check out the FAQ links below.
Important: Installation Order
iClone 6
Indigo Plugin (iClone 6 should not be running)
Indigo RT For iClone 6
How to install the iClone Indigo Render Plug-in?
http://faq.reallusion.com/index.php?action=article&cat_id=011001007001&id=713&lang=
How to install Indigo RT for iClone?
http://faq.reallusion.com/index.php?action=article&cat_id=011001007001&id=714&lang=
And if you are having problems locating your Indigo RT For iClone activation code, please see below.
How to get "Indigo RT for iClone" activation key? (Step 3)
http://faq.reallusion.com/index.php?action=article&cat_id=001001&id=199&lang=
Threaded View
Threaded View
Forum Post How To Install The Indigo RT Suite By Peter (RL) ( 10 Years Ago )
Forum Post Hi Peter thanks for the info. I have tried this multiple times still... By Virtual Architec ( 10 Years Ago )
Forum Post What I did different and what seems to work is install Indigo RT for... By animagic ( 10 Years Ago )
Forum Post Hi, i have also the same problem with Indigo RT. I have tried... By brand468 ( 10 Years Ago )
Forum Post I found that when I copied and pasted the license key for the Render... By brrymchlsn ( 10 Years Ago )
Forum Post Same problem here with iclone Indigo RT. Installed everything, put in... By lvandepaer ( 10 Years Ago )
Forum Post I just received all this software and installed it and everything says... By Sigurd8 ( 10 Years Ago )
Forum Post i have been trying for days and days to resolve this and cannot!!!!!... By richard666 ( 9 Years Ago )
Forum Post [quote][b]richard666 (1/5/2015)[/b][hr]i have been trying for days and... By Peter (RL) ( 9 Years Ago )
Forum Post peter thank you for replying AND solving this issue. i am no... By richard666 ( 9 Years Ago )
Forum Post [quote][b]Peter (RL) (1/6/2015)[/b] In iClone 6 go to "Plugins >... By hattori kun ( 9 Years Ago )
Forum Post Hi Peter, my Indigo render plugin has disappeared from the menu bar in... By pi-qui ( 9 Years Ago )
Forum Post [quote][b]pi-qui (10/7/2015)[/b][hr]Hi Peter, my Indigo render plugin... By Peter (RL) ( 9 Years Ago )
Forum Post I tried everything described here, but the Indigo plugin is no longer... By pi-qui ( 9 Years Ago )
Forum Post Hi Peter. Thanks for the Hint but it does not work with my iclone... By cducharme ( 9 Years Ago )
Forum Post [quote][b]cducharme (1/5/2015)[/b][hr]Hi Peter. Thanks for the Hint... By Peter (RL) ( 9 Years Ago )
Forum Post I have been having the same problem as everyone else. I tried the... By dwcook281 ( 9 Years Ago )
Forum Post I was not able to locate my activation key. In my emails I only see... By 45thdiv ( 9 Years Ago )
Forum Post [quote][b]45thdiv (1/13/2015)[/b][hr]I was not able to locate my... By wires ( 9 Years Ago )
Forum Post [quote]The email should contain 3 "serial numbers", one for iClone 6,... By 45thdiv ( 9 Years Ago )
Forum Post So, I gave in and bought Indigo and after a few attempts, I was told... By Lost Filmmaker ( 9 Years Ago )
Forum Post [quote][b]Lost Filmmaker (1/13/2015)[/b][hr]So, I gave in and bought... By theschemer ( 9 Years Ago )
Forum Post I can't find C:\Program Files\Indigo RT\ By Lost Filmmaker ( 9 Years Ago )
Forum Post [quote][b]Lost Filmmaker (1/13/2015)[/b][hr]I can't find C:\Program... By Lost Filmmaker ( 9 Years Ago )
Forum Post [quote][b]Lost Filmmaker (1/14/2015)[/b][hr][quote][b]Lost Filmmaker... By wires ( 9 Years Ago )
Forum Post [quote][b]wires (1/14/2015)[/b][hr][quote][b]Lost Filmmaker... By Lost Filmmaker ( 9 Years Ago )
Forum Post I just checked and I do have RT installed, but it has Trial Version... By 45thdiv ( 9 Years Ago )
Forum Post Well, after all is done, I went to start iClones6 and "Load Resource... By 45thdiv ( 9 Years Ago )
Forum Post Well, here is another interesting thing. I have a new machine running... By 45thdiv ( 9 Years Ago )
Forum Post I have everything installed, and I followed the steps. I added my... By 45thdiv ( 9 Years Ago )
Forum Post All my applications look like they are working now. Next, on to... By 45thdiv ( 9 Years Ago )
Forum Post Success, the redownload did the job. By Lost Filmmaker ( 9 Years Ago )
Forum Post 6.02 seems to be unsupported. I kept reinstalling but couldn't see the... By hattori kun ( 9 Years Ago )
Forum Post I had the same problems installing Indigo as many have reported here.... By prairiemain ( 9 Years Ago )
Forum Post iC6 installed and work perfectly all settings are correct and can send... By Lawsuit Pending Records ( 9 Years Ago )
Forum Post [quote][b]Lawsuit Pending Records (2/24/2015)[/b][hr]iC6 installed and... By Peter (RL) ( 9 Years Ago )
Forum Post Hi Peter I am using the Indigo for iClone version I received a... By Lawsuit Pending Records ( 9 Years Ago )
Forum Post When you see all those gibber-jabber numbers in the trial version of... By leshenderson ( 9 Years Ago )
Forum Post HI Removed the plugin and the Indigo RT Software. Installed again... By Lawsuit Pending Records ( 9 Years Ago )
Forum Post [Moderator Removed] - Posting profanity is against forum rules.... By JC Weatherby ( 9 Years Ago )
Forum Post Reallusion Support kindly explained that the SERIAL NUMBER provided... By JC Weatherby ( 9 Years Ago )
Forum Post I don't know what I did the first time I install the plugin but i got... By msjaebea ( 9 Years Ago )
Forum Post I tried everything for once I even followed the instructions, it was... By Lawsuit Pending Records ( 9 Years Ago )
Forum Post Hello, For install Indigo with iClone 6.1, the only way i found. 1 )... By guy launay ( 9 Years Ago )
Forum Post Hi I installed iClone 6, Indigo Render Plugin and Indigo RT for iClone... By cducharme ( 9 Years Ago )
Forum Post [quote][b]cducharme (6/13/2015)[/b][hr]Hi I installed iClone 6, Indigo... By Lawsuit Pending Records ( 9 Years Ago )
Forum Post Thanks for Your advice. I did uninstall Indigo and redo the install... By cducharme ( 9 Years Ago )
Forum Post I have IC 7 installed now and need to install the Indigo RT and IC 7... By Alien Maniac ( 7 Years Ago )
Forum Post [quote][b]Space Rider (12/6/2017)[/b][hr]I have IC 7 installed now and... By TonyDPrime ( 7 Years Ago )
