edvsauer
edvsauer
verfasst 10 Jahre zuvor
Gruppe: Forum Members
Letztes Login: 5 Jahre zuvor
Besuche: 52
I've used TTS and the next day I want to edit the text. Is there a way to do that, or is there a text-file saved somewhere I could open so i can edit the text?
Sefardi
Sefardi
verfasst 15 Jahre zuvor
Letztes Login: 2 Jahre zuvor
Besuche: 2.4K
Gruppe: Administrators
Beiträge: 23.1K,
Besuche: 36.6K
maxomax07 (10/18/2011) I this applicable to CTA? because I canot find the tab in the timeline???? If you open your timeline, then select your character, you should see the Facial button shown. Just select this to get access to the voice clip.
Sefardi
Sefardi
Besuche: 2.4K
jbacon
jbacon
Letztes Login: 13 Jahre zuvor
Besuche: 4
Many thanks for the reply. I was sure there was a way to edit TTS audio files...just couldn't find it. Jonathan :)
planetstardragon
planetstardragon
Letztes Login: Letztes Jahr
Beiträge: 11.5K,
Besuche: 46.0K
Hi Jonathan, Welcome to the Forum, You should be able to these tasks in the Timeline. basically the TTS gets recorded to a file, and you cut up the file and spread it out or delete it / or parts of it, in the timeline. Open the timeline, click one the "Face" tab and the file will appear under the "Viseme" track. you can delete, edit , truncate the file from there. Cheers.
jbacon
jbacon
Besuche: 4
Is there a way to delete or edit an existing text-to-speech recording without deleting the actor to which the audio is attached? Also is there a way to add a pause into the text being converted to audio? I'm using a couple of Cepstral voices (William and Linda). Jonathan
