jbacon
jbacon
Posted 13 Years Ago
Last Active: 11 Years Ago
Visits: 4
Is there a way to delete or edit an existing text-to-speech recording without deleting the actor to which the audio is attached? Also is there a way to add a pause into the text being converted to audio? I'm using a couple of Cepstral voices (William and Linda). Jonathan
planetstardragon
planetstardragon
Posted 13 Years Ago
Posts: 11.5K,
Visits: 45.9K
Hi Jonathan, Welcome to the Forum, You should be able to these tasks in the Timeline. basically the TTS gets recorded to a file, and you cut up the file and spread it out or delete it / or parts of it, in the timeline. Open the timeline, click one the "Face" tab and the file will appear under the "Viseme" track. you can delete, edit , truncate the file from there. Cheers.
jbacon
jbacon
Posted 13 Years Ago
Visits: 4
Many thanks for the reply. I was sure there was a way to edit TTS audio files...just couldn't find it. Jonathan
Sefardi
Sefardi
Posted 13 Years Ago
Last Active: 4 days ago
Visits: 2.4K
I this applicable to CTA? because I canot find the tab in the timeline????
Posted 13 Years Ago
maxomax07 (10/18/2011) I this applicable to CTA? because I canot find the tab in the timeline???? If you open your timeline, then select your character, you should see the Facial button shown. Just select this to get access to the voice clip.
Sefardi
Sefardi
Posted 13 Years Ago
Visits: 2.4K
edvsauer
edvsauer
Visits: 52
I've used TTS and the next day I want to edit the text. Is there a way to do that, or is there a text-file saved somewhere I could open so i can edit the text?
