Text to Speech
https://forum.reallusion.com/Topic79141.aspx
Print Topic | Close Window
By jbacon - 15 Years Ago
Is there a way to delete or edit an existing text-to-speech recording without deleting the actor to which the audio is attached?
Also is there a way to add a pause into the text being converted to audio? I'm using a couple of Cepstral voices (William and Linda).
Jonathan
By planetstardragon - 15 Years Ago
Hi Jonathan,
Welcome to the Forum, You should be able to these tasks in the Timeline. basically the TTS gets recorded to a file, and you cut up the file and spread it out or delete it / or parts of it, in the timeline. Open the timeline, click one the "Face" tab and the file will appear under the "Viseme" track. you can delete, edit , truncate the file from there.
Cheers.
Many thanks for the reply. I was sure there was a way to edit TTS audio files...just couldn't find it.
Jonathan :)
By Sefardi - 15 Years Ago
I this applicable to CTA? because I canot find the tab in the timeline????
By Peter (RL) - 15 Years Ago
maxomax07 (10/18/2011)
If you open your timeline, then select your character, you should see the Facial button shown. Just select this to get access to the voice clip.
I found it!!
Thanks
By edvsauer - 10 Years Ago
I've used TTS and the next day I want to edit the text. Is there a way to do that, or is there a text-file saved somewhere I could open so i can edit the text?
