toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Yo, works... Thanx! Though there is one pack of four that does not work: https://www.reallusion.com/ContentStore/Pack/mech-constructor-spiders-and-tanksMaybe someone else has this pack and wants to test...
rosuckmedia
rosuckmedia
Last Active: 7 Months Ago
Posts: 3.2K,
Visits: 4.8K
Hi Gurgen, Wow, you are a genius, it works.πππππ Many many thanks Greetings Robert
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Oh, will test that as soon I'm in the studio! Curious if this will work for our robots... Let you know! Thanx
Posts: 5.3K,
Visits: 16.8K
toystorylab (1/8/2023)
4u2ges (1/7/2023) One more idea. I do not have that pack, but did you guys try to rebuild perform list? You have to use Pack in Perform list editor, then clear perform list and reapply all motions back from saved list.Hm, never done this before... When I open "Perform List Editor" and click "Pack", I get prompted to select a folder on my PC, when I do so, nothing happens. I expected it would save all performs so I can reapply... What am I doing wrong? I am getting old I guess :Whistling: I got the reply to my FT ticket, that is was never possible to extract embedded motions with Pack button within the Perform List. Well, that is apparently true. But, you still can extract those motions with one click. I finally recalled how I did it a few months back.... ;)
And that makes all motions to loop!
1. Send (or open) your prop with Embedded Perform List motions to (in) CC 2. Go to "Character" top menu and select "Convert to Creature". 3. The message would popup saying that Perform was found in current prop and if you want to keep it. 4. Hit OK, select folder and all perform motions would be extracted and saved in .rlMotion format. 5. At this point the Prop is converted to Creature and the perform list is re-populated automatically. 6. Send your Prop (converted to Creature) back to iClone and all perform motions would now loop.
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Hm, that sucks! :pinch:
Posts: 5.3K,
Visits: 16.8K
What am I doing wrong? I do not think you're doing something wrong. Just a couple of updates back it used to work and now it does not. I just tried to extract motions from cat and a dog (which I successfully did in the past) and it does not work anymore (not in IC, nor in CC). :crazy: https://www.reallusion.com/FeedBackTracker/Issue/Pack-button-in-Perform-List-Editor-does-not-extract-motions-anymore
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Method Robert works for straight walk, but not for turn... Method 4u2ges Curve editor works fine, for turns you need to do this with all values. With this method I was able to let Mech walk in an endless circle using "Legs_Heavy_Walk_Turn_47_R"
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
Hi Mark, Thank you very much. Will soon also buy some.
Hi Gurgen, Thanks for the tip.
Greetings Robert
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
4u2ges (1/8/2023)
As you can see in my thread below the problem is that the curve editor didn't see any move... But you are looking at Z, while Move forward is Y (in iClone) ;) And once you fix it, you can add it to perform and remove the old one (that is what developer should actually do).
Oh! You're right. I really understand why I missed this.... if I had known this thread would not have existed :blink:
Thank guys . I have 2 ways to fix this ;)
