Fionn (RL)
Fionn (RL)
Visits: 614
v8.12 released on Nov. 17th, 2022 Bug fixes. Fixed:
- Motion Director's Snap to Surface function doesn't work on terrain that relies on a height map.
- Another character's bone can be set as a Reach Target.
- Curve Editor sets duplicate keys on the same frame. Feedback Tracker
Several added functions and enhancement in Smart Content Manager.
Added: - Search items by parent folder name.
- Thumbnails can be adjusted to be extra large, large, or medium.
- New List and Details view.
- Animated thumbnails for motion assets.
- Ability to sync Template and Custom categories.
- New navigation bar below the Template and Custom tabs. It displays the content folders by hierarchy.
- New icons for major content info on top of the content thumbnails.
Enhanced: - Enhanced drag-and-drop behavior for folders and files.
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
@Fionn Thanks for the Updates and information. Greetings Robert
gordryd
gordryd
Visits: 8.0K
Cannot install the latest update using RL Hub. Even with Norton Auto-Protect and Firewall disabled, the "Data Protector" still runs and blocks the installation. I can't exclude the process from Data Protector because every time it runs it is given a different name (consisting of random numbers). Why doesn't the install path just include the name (like the Anima path above it) so that I can exclude it from being blocked?
mark
Posts: 4.9K,
Visits: 16.7K
gordryd (11/18/2022)
Cannot install the latest update using RL Hub. Even with Norton Auto-Protect and Firewall disabled, the "Data Protector" still runs and blocks the installation. I can't exclude the process from Data Protector because every time it runs it is given a different name (consisting of random numbers). Why doesn't the install path just include the name (like the Anima path above it) so that I can exclude it from being blocked?  Lately I've been having the same issue! :crazy:
SCE
Visits: 982
You should be able to install it by simply turning off Data Protector for a period of time (or indefinitely). In the Norton hub, open Device Security, then click Settings (top row between Report Card and Help), then in Settings click Antivirus, Data Protector, and Off. Then Apply your changes and close.
mark
Posts: 4.9K,
Visits: 16.7K
SCE (11/18/2022) You should be able to install it by simply turning off Data Protector for a period of time (or indefinitely). In the Norton hub, open Device Security, then click Settings (top row between Report Card and Help), then in Settings click Antivirus, Data Protector, and Off. Then Apply your changes and close.
...one should, but it hasn't worked for me.
Posts: 15.8K,
Visits: 31.3K
My install files are stored at: C:\Users\<username>\AppData\Local\Reallusion\RLDownloads, which is the default location for the Hub. Maybe check there?
gordryd
gordryd
Visits: 8.0K
How do I view the: - Animated thumbnails for motion assets.
The menu items for "Animated Thumbnail" in the Content Manger are checked, but nothing seems to actually animate? Does it only work on certain motions (I tried the RL Studio Mocap series)? Is this supposed to work/look like the ActorCore website?
Posts: 23.1K,
Visits: 36.6K
gordryd (11/27/2022)
The menu items for "Animated Thumbnail" in the Content Manger are checked, but nothing seems to actually animate? Does it only work on certain motions (I tried the RL Studio Mocap series)? Is this supposed to work/look like the ActorCore website? If you select a motion pack in Content Manager that has animated thumbnails, then they will display as shown below. Not all packs have animated thumbnails. 76% of original size (was 661x19) - Click to enlarge
yorgon
yorgon
Visits: 316
hello, does reallusion have soft body physics on its roadmap? When will this feature be shown?
