By Fionn (RL) - 3 Years Ago
v8.12 released on Nov. 17th, 2022 Bug fixes. Fixed:
- Motion Director's Snap to Surface function doesn't work on terrain that relies on a height map.
- Another character's bone can be set as a Reach Target.
- Curve Editor sets duplicate keys on the same frame. Feedback Tracker
Several added functions and enhancement in Smart Content Manager.
Added: - Search items by parent folder name.
- Thumbnails can be adjusted to be extra large, large, or medium.
- New List and Details view.
- Animated thumbnails for motion assets.
- Ability to sync Template and Custom categories.
- New navigation bar below the Template and Custom tabs. It displays the content folders by hierarchy.
- New icons for major content info on top of the content thumbnails.
Enhanced: - Enhanced drag-and-drop behavior for folders and files.
By rosuckmedia - 3 Years Ago
@Fionn Thanks for the Updates and information. Greetings Robert
By gordryd - 3 Years Ago
Cannot install the latest update using RL Hub. Even with Norton Auto-Protect and Firewall disabled, the "Data Protector" still runs and blocks the installation. I can't exclude the process from Data Protector because every time it runs it is given a different name (consisting of random numbers). Why doesn't the install path just include the name (like the Anima path above it) so that I can exclude it from being blocked?
By mark - 3 Years Ago
gordryd (11/18/2022)
Lately I've been having the same issue! :crazy:
By SCE - 3 Years Ago
You should be able to install it by simply turning off Data Protector for a period of time (or indefinitely). In the Norton hub, open Device Security, then click Settings (top row between Report Card and Help), then in Settings click Antivirus, Data Protector, and Off. Then Apply your changes and close.
SCE (11/18/2022) You should be able to install it by simply turning off Data Protector for a period of time (or indefinitely). In the Norton hub, open Device Security, then click Settings (top row between Report Card and Help), then in Settings click Antivirus, Data Protector, and Off. Then Apply your changes and close.
...one should, but it hasn't worked for me.
By animagic - 3 Years Ago
My install files are stored at: C:\Users\<username>\AppData\Local\Reallusion\RLDownloads, which is the default location for the Hub. Maybe check there?
How do I view the: - Animated thumbnails for motion assets.
The menu items for "Animated Thumbnail" in the Content Manger are checked, but nothing seems to actually animate? Does it only work on certain motions (I tried the RL Studio Mocap series)? Is this supposed to work/look like the ActorCore website?
By Peter (RL) - 3 Years Ago
gordryd (11/27/2022)
If you select a motion pack in Content Manager that has animated thumbnails, then they will display as shown below. Not all packs have animated thumbnails.
By yorgon - 3 Years Ago
hello, does reallusion have soft body physics on its roadmap? When will this feature be shown?
By bad_character - 3 Years Ago
What is the animated thumbnail format? Doesn't appear to be animated png...
bad_character (12/9/2022) What is the animated thumbnail format? Doesn't appear to be animated png... I believe it's GIF.
By 0oseven - 3 Years Ago
Peter (RL) (11/28/2022)
The menu items for "Animated Thumbnail" in the Content Manger are checked, but nothing seems to actually animate? Does it only work on certain motions (I tried the RL Studio Mocap series)? Is this supposed to work/look like the ActorCore website? If you select a motion pack in Content Manager that has animated thumbnails, then they will display as shown below. Not all packs have animated thumbnails.  STILLNOT WORKING AFTER 1 MONTH - ANYONE KNOW IF THIS HAS THIS BEEN REPOERTED?
I don't if it has been reported but it doesn't work for me either.
I placed a feedback item with support re thumbnails not working. This was reply "Now we only set animated thumbnails for motions,so you can't see animated thumbnails for other contents.But not all packs have animated thumbnails." Not exactly an informative reply !!!! Of course animation not expected for "other content" other than motions. So not all motion packs have animated thumbs - have to ask why and how do we know which ones supposed to animate ? Do we now have to assume any user imported motions will not have this feature. ? With these anomalies why make such a Big feature thing about it in promoting IC8 ?
The thumbnails will have to be created; existing thumbnails will not suddenly become animated. It seems that newer motion packs have them, because I have seen it.
I think I read somewhere that they are animated GIFs. So iClone 8 has the capability to display animated thumbnails but if the thumbnail is it older (before this feature was introduced) they will not animate.
So obviously user created motions will not have an animated thumbnail unless one was created for them..
