iC8 to UE5 Hair Issues
Posted By lightbearer 3 Years Ago
3
4
new-own
new-own
Posts: 86, Visits: 353
pxlpshr42 (10/26/2022)
My current understanding is that the CC Unreal hair shader needs an accumulation buffer (data from the previously rendered frame) to properly render out the hair opacity.
UE5 editor uses by default TSR anti-aliasing with such an accumulation buffer so the hair looks ok in the UE5 editor.
If you use Movie Render Queue then make sure to use Temporal Super-Resolution (TSR) Anti-aliasing setting, otherwise you will see these dithering artefacts.
Spatial sampling or temporal sampling will not help you here.
You also need to render at 30fps or higher otherwise the accumulation buffer will give you a lot of ghosting on fast motions
The hair LWHQ MaterialInstance has also Alpha Multiplier parameter which can be used to increase the hair opacity.
Most hairstyles I tried look bad (too bright) under Lumen.
Most hairstyles I tried turn fully black when using HDRIBackdrop IBL lighting with raytraced shadows.
 I have noticed that when I get the viewport/camera so close to the hair, it starts showing up.
https://forum.reallusion.com/uploads/images/c4fdac76-09b7-49ed-b2dd-c6dc.png
lightbearer
lightbearer
Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)
Posts: 88, Visits: 519
It's unfortunate really, because my project is 24fps and I'm using the anti-alias workflow from William Faucher's YouTube MRQ video (from awhile back). Also, unfortunate because this isn't mentioned on Reallusion's page dedicated to tweaking settings for UE5:
Character Creator to Unreal Engine 5 Best Practice - Reallusion Magazine
The Kevin model looks great in the demo videos, but I've had less luck with a different character and hairstyle. For this project, I have moved on to Groom assets created in Blender and exported/imported as Alembic files.
pxlpshr42
pxlpshr42
Junior Member (102 reputation)Junior Member (102 reputation)Junior Member (102 reputation)Junior Member (102 reputation)Junior Member (102 reputation)Junior Member (102 reputation)Junior Member (102 reputation)Junior Member (102 reputation)Junior Member (102 reputation)
Posts: 5, Visits: 69
lightbearer (10/26/2022)
The 30fps I mentioned was just a ballpark number. If you have static camera with people in front of it then you might not see artefacts. If you have a static camera and people driving by in a fast car you might encounter them.
This is a good writeup from Epic staff:
https://dev.epicgames.com/community/learning/tutorials/GxdV/unreal-engine-demystifying-sampling-in-movie-render-queue
Note that he recommends odd number of temporal samples (Faucher used even number of temporal samples).
I also think that Alembic groom is the way to go for UE5 users. It's the foundation of MetaHuman hair and should have a good out-of-the box support.
Unfortunately I haven't found a large collection of good looking premade groom hairstyles for Blender. Does that exist?
I also have a hard time to create black hair. All the hair models I tried come with brownish hair and when I reduce the base color multiplier in the Unreal shader a lot of red color artefacts appear.
So looks like I am tweaking the wrong parameter here.
lightbearer
lightbearer
The asset I used is a good start and allows you to customize as necessary. I exported the model from UE5, brought it into Blender and then used the assets for the hair, beard and brows. Example below. Note that any issues are related to my technical deficiencies and not the product itself.
https://forum.reallusion.com/uploads/images/e97901ac-86d7-4b08-a276-2cf0.jpg
I'm not affiliated with the asset's creator and am not receiving any consideration, but if you're interested learning more, link below:
Blender Facial Hair Toolkit (gumroad.com)
Kalex
Kalex
Posts: 602, Visits: 6.5K
Have you tried playing around with the "alpha power" in Unreal Material Editor ?
lightbearer
lightbearer
Kalex (11/5/2022)
Yes.
Kalex
Kalex
you weren't satisfied with the results though ?
tomelissaconway
tomelissaconway
Last Active: 9 days ago
Posts: 91, Visits: 3.0K
I'm still trying to figure out what's wrong. In UE5, this is a screen snip of the hair materials. Note the jagged appearance of the transparencies. Is this how it's supposed to look? tx
 can
0
lightbearer
lightbearer
lightbearer (11/7/2022)
Kalex (11/5/2022)
No, various settings still yielded the issues I previously posted screenshots of.
Yes.
lightbearer
lightbearer
tomelissaconway (11/11/2022)
 can
I don't believe that the thumbnails are entirely indicative of the way the material should look in the viewport. Lighting and Engine Scalability settings play a bigger part in how the materials will look.
3
4
